Old 10-21-2010, 10:43 AM
Pokoki's Avatar
Member #7722
Outlaw 525 with CT racing exhaust dyno results
I have a STOCK 2007 Polaris Outlaw 525 IRS. I got my CT Racing exhaust on Friday, so Sunday was the install and dyno day.
After looking at CT Racing's dyno, I knew the peak HP number after just an exhaust and jet kit was high, so we did pre and post exhaust runs. We used a Dynojet Research Dyno.
It was amazing how lean my machine was running in stock form. We ended up taking out the stock 148 jet and after several trial runs found that the 160 jet was as almost perfect as you could get power/torque wise as well as the air to fuel ration.
After it was all said and done here are the results...
Stock: 39.90 hp and 29.44 torque
CT racing exhaust with jet kit: 41.74 hp and 30.63
Note: We broke 42 hp once out of three runs on the 160 jet but it laid down nearly identical 41.74 hp runs back to back. Not nearly the 48.94 hp that CT racing claims...
I cannot get the dyno chart to upload. I will keep working on that part.
Old 10-21-2010, 10:47 AM
ZEUS's Avatar
Member #7484
Very interesant.
Polaris Sportsman 850 XP Camo 2010 - The Best
Honda Rancher 420 4x4 AT ES 2009 - The best MPG !!
Old 10-21-2010, 04:30 PM
terrasmak's Avatar
Member #7775
Send a message via Yahoo to terrasmak
Full system or slip on.
Old 10-22-2010, 07:54 AM
Pokoki's Avatar
Member #7722
Complete full system
Old 11-26-2010, 08:12 PM
outlawman 525s's Avatar
Member #5124
39 stock,polaris and alot of reviewers all claim 49-50 hp in stock form,i'm dyno'ing soon and will post asap after it happens
in the world of outlaws,we band 2gather and run as the fastest of the fast.Laughing at the yamahoppers,and the rest of them slow rides outherepilot license required,i meant firearms,two gun minimum!!!!!!!!!!!!!!!!!!!!and maybe a few grenadiersnot here
Old 11-30-2010, 05:31 PM
1wicked55's Avatar
Member #9669
The stock #s are average for all 450 and based atv's. But the #'s with the pipe are low. I would say you could gain more hp with some intake mods. My yfz with just pipe and filter pulled 49hp, and my 06 trx pulled 47.9 hp
Old 02-22-2011, 07:26 PM
CB BLR's Avatar
Member #12304
Were these dyno pulls done with slicks or the stock tires?...knobby tires tend to slip on the dyno drum and show lower horsepower numbers.
Chris
Old 02-23-2011, 11:12 PM
Sakkie's Avatar
Member #9601
I have a 2007 525 irs, Top is gas flowed, bigger intake, HMF slip on, and it produced only 48 hp. But i must also mention that this run was done on 22" tires, so i expect it to increase quite a bit on 20's.
Old 03-10-2011, 01:50 AM
ffracing's Avatar
Member #12808
Get yourself a rat stack for that thing and you'll see 45 plus. The IRS has to restrictive of an intake and leaves a lot on the table. 42 is the average with those mods mentioned. The actual KTM quads are not doing much above that with same mods.
Old 03-11-2011, 06:58 PM
CB BLR's Avatar
Member #12304
One of the unique aspects of dynoing an IRS Outlaw...is that in order to get accurate dyno readings...you must loosen the pre-load on the rear shocks...and strap the rear of the quad down...so that the axels are parrallel to the dyno/ground...elswise...you will loose 3-5 horsepower thru the CV joints when they are at an angle.
You must also use dyno slicks...or you will not get accurate data.
Chris
best exhaust for 525 irs
best exhaust for outlaw 525
best exhaust for polaris outlaw 525 irs
best pipe for outlaw 525 irs
ct racing exhaust
ct racing pipe for outlaw
exhaust for a outlaw 525
how can i get more horsepower out of my polaris outlaw 525
outlaw 525 ct racing exhaust jetting recommendations
outlaw 525 dyno
outlaw 525 horsepower
outlaw 525s exhaust
outlaw ct exhaust
polaris 525 dyno
polaris outlaw 525 best exhaust
polaris outlaw 525 horsepower
polaris outlaw 525 hp
polaris outlaw 525 hp rating
polaris outlaw 525 irs exhaust
polaris sportsman horsepower chart
Dyno Port clutching chuckorlando Polaris Sportsman 0 09-12-2010 04:18 AM
Dyno-ed Exhausts?? InkedAdrenaline ATV Performance Modifications 0 08-12-2010 04:10 PM
other outlaw exhaust fit a 2010 IRS model? rob1994 ATV Repair and Maintenance 1 08-05-2010 06:08 PM
other outlaw exhaust fit a 2010 IRS model? rob1994 Polaris Outlaw 1 08-04-2010 02:19 PM
Oil Testing Results Naga ATV Repair and Maintenance 9 03-24-2010 02:51 AM
