Old 10-21-2010, 03:48 PM
slyboy360's Avatar
Member #8405
06 outlaw 500 front brake prob
hey guys i got this weird prob with my front brakes i have a 06 outlaww 500 and when going slow speeds "15-20 mph" the brakes work great, but now when going faster 35-40 mhp" i have to pull the lever in let go and pull in again basicly pumping till presure builds. I was tolld there was air in the lines but we bleed and bleed them and still the same. The master is not leaking and holding fulid if some one could help that would be great. And how can you tell if the master is gone bad?
Old 10-21-2010, 04:08 PM
Old 10-21-2010, 04:20 PM
terrasmak's Avatar
Member #7775
Send a message via Yahoo to terrasmak
Sounds like a front rotor is bent, check the run out on it.
Old 10-21-2010, 04:40 PM
slyboy360's Avatar
Member #8405
the bike is torn down and yes the left front rotor is bent ill replace it and hope it works thanks
Old 10-21-2010, 04:48 PM
terrasmak's Avatar
Member #7775
It will , when you have a bent rotor it opens the caliper with every turn. Then you have to pump the brakes to reseat the pads to use them.
brake pads polaris outlaw
change outlaw front brakes
how do i bleed my brakes 525 outlaw
how to bleed brakes on polaris outlaw
how to bleed outlaw 500 front brakes
polaris front brake problem
polaris outlaw 500 brakes
polaris outlaw 500 front brakes bleeding
polaris outlaw 525 brakes issues
polaris outlaw 525 irs front brakes problems
polaris outlaw bent
polaris outlaw bent rotor
polaris outlaw brake caliper thread
polaris outlaw brake fluid
polaris outlaw front brake problems
polaris outlaw front brakes
problems with polaris front brakes
2010 Outlaw 450 mxr Brake-in period? salcedo1135 2010 4 10-28-2010 05:57 AM
front brake line replacement davesdragon ATV Brakes & Suspension 3 09-14-2010 11:18 AM
06 Outlaw 500 brake pads?? dytod82 Polaris Outlaw 0 06-12-2010 03:35 PM
Front brake fluid res. stickem Polaris Sportsman 0 01-27-2010 03:49 PM
04 front brake calipers kirbyk ATV Parts for Sale 1 08-28-2009 12:46 PM
