11-15-2010, 10:08 AM
Member #9164
Polaris Outlaw 525s Leaky Clutch
Hello All,
Trying to find info online about this, but couldn't seem to find anything. I have a 2008 outlaw 525s that is leaking black fluid from around the clutch lever. From what I've read this is supposed to be red fluid. I've never added anything to it and owned the bike for a little over a year (bought new). Is it possibly that these push motor oil from the engine into the clutch line? Any other thoughts? Is there a slave that needs to be serviced or maintained or known to go bad on these? Thanks for your response.
11-15-2010, 02:55 PM
11-15-2010, 06:15 PM
Member #7775
Black fluid at the lever would be a bad piston seal on the master cylinder. Order a rebuild kit, replace it and bleed the system. Also you should flush the system at least yearly.
11-22-2010, 09:38 AM
Member #9164
Thanks. Anyone have suggestions about the best place on the web to order for Polaris parts? I've used bikebandit, but they seem to take a while. Local dealer always seems to just be way to spendy.
2008 Polaris Outlaw 525s
Moose Racing Nerfs and Heelguards
2004 Honda 250EX
AC Racing Nerfs
2003 Suzuki LT80
AC Racing Nerfs
FMF Powercore Exhaust
2003 Kawasaki KFX80
AC Racing Nerfs
07 polaris outlaw clutch leak, 2008 525 outlaw slave cylinder info, 2008 polaris outlaw 450mxr, how to bleed the hydraulic clutch, 2008 polaris outlaw 525 s clutch kits, clutch kit for outlaw 525 irs, fixing 2008 polaris outlaw clutch chatter, how change a clutch on a polaris outlaw, how to change clutches on polaris outlaw 525, how to fix 07 polaris 525 outlaw irs hydraulic clutches, hydraulic clutch problems on a polaris outlaw, outlaw 525 clutch leak, outlaw 525 clutch problem, polaris 525 outlaw clutch, polaris outlaw 525 clucth repair, polaris outlaw 525 clutch, polaris outlaw 525 clutch kit, polaris outlaw clutch, polaris outlaw clutch fluid, polaris outlaw clutch oil, polaris outlaw oil leak
