Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix
Polaris Phoenix Discussions relating to the Polaris Phoenix
Old 05-21-2011, 04:11 PM
Rob1976's Avatar
Member #15258
2009 Phoenix 200
Hello all, I was wondering if anyone could help point me in the right direction with a problem we have with my wifes Phoenix.
I noticed a few days ago, that there was a nut missing on the carb boot that goes from the carb to the cylinder, it had issues running and I figured that it was due to an air leak there. So i replaced the nut, and it started running great, for a little while. Now it is running poorly again.
When the bike is cool, it starts right up, but when it gets warm, it wont run unless choke is used, and then it sputters and eventually it will not start until or continue running until cool again.
Do any of you feel that a valve adjustment is due, or necessary? Could it be the culprit of the no start when warm? Could it be an electrical issue?
Gas is not old, has had a fresh oil change with recommended oil from polaris dealer.
Is there an inline fuel filter that I can check for cleanliness to see if it in fact only starving from proper fuel flow?
Thanks in advance for any possible help you all might throw my direction as I am at a standstill with this issue and I don't really want to pay labor rates at a dealer service department.
Old 05-21-2011, 04:22 PM
cwlongshot's Avatar
WELCOME!
I would first look at the fuel filter and then run a couple tanks of SEA FOAM. A carb rebuild may be in order.
Old 05-21-2011, 05:56 PM
Old 05-21-2011, 07:24 PM
Rob1976's Avatar
Member #15258
Can you tell me where the fuel filter is located? Im not too failiar with this machine yet. thanks.
Old 05-22-2011, 09:53 AM
Rob1976's Avatar
Member #15258
So I found the filter, replaced it, and it still has the issue. When it wont start normally, I can get it to start by starting with full choke, and holding the throttle full open. Any ideas what this could be?
2007 polaris 200 phoenix required oil
2009 polaris phoenix 200 oil change
2010 polaris phoenix gas filter
change oil for 2009 polaris phonix
how to change oil on a polari phoenix
how to change oil on a polaris phoenix
how to change oil on polaris phoenix 200
how to change oil onpolaris 200
how to change starter on polaris phoneix 200
mud flaps for polaris phoenix
oil change for polaris phoenix
oil fill location polaris phoenix 200
polaris pheonix gas filter
polaris phoenix fuel filter
polaris phoenix fuel gauge
polaris phoenix oil
polaris phoenix oil change
polaris phoenix oil filter
what oil to use for a polaris phoenix 200
Looking to buy phoenix 200 cheque28 Polaris Phoenix 9 02-29-2012 06:50 PM
Do you like your Phoenix? shadetree Polaris Phoenix 15 01-27-2012 12:39 PM
05 phoenix jjzg24 ATV Repair and Maintenance 1 11-04-2010 06:30 AM
05 phoenix jjzg24 ATV General Discussion 1 10-30-2010 04:42 PM
2009 Polaris Phoenix 200 Prddave 2009 0 03-08-2010 12:51 PM
