07-02-2011, 09:56 PM
Member #16463
driven clutch removal 2008 Phoenix 200
Does anyone know how to remove the driven clutch? I have used a strap wrench to hold the clutch housing still but the nut and the piece in front of it keep turning like they are ratcheting over a bump with pressure. Any help is appreciated. Thanks.
07-03-2011, 05:05 AM
07-03-2011, 09:28 AM
Member #16463
Thanks. Sorry for the rush to questions but I was helping my uncle replace the drive belt when we noticed the driven clutch wiggling slightly. Now we can't figure out if there is something special to get it off.
09-23-2011, 08:05 AM
Member #18950
Just wondering if you ever found a way to get the clutch off?, I replaced my belt and I was told you need to take the clutch off and clean it. I'm having the same problem getting it off.
09-25-2011, 11:25 AM
Member #18580
the driven clutch in on a splined shaft, it just slides right off after removing the bolt. you need a special puller bolt to remove the drive clutch. you should just be able to blow the drive clutch out on the machine
2000 scrambler 400 2 stroke 2wd (stock)
2006 scrambler 500 4wd (stock)
2007 scrambler 500 4wd (stock)
2012 scrambler 500 4wd (stock)
09-25-2011, 03:09 PM
Member #18950
My problem is getting the bolt off, the whole thing turns when attempting this.
I got the new belt on and works, but it seems to be stuck in high gear. Doesn't want to pull out and struggles climbing a hill. Once it gets going its good till you stop or go up a hill.
It's almost like the belt is too short, keeping the back pulley apart and not letting it close up.
I checked the part # and its supposedly the right belt, got it from the Polaris dealer.
Any suggestions?
09-25-2011, 03:22 PM
Member #18580
sounds like one of the springs in one of the clutches is dead or maybe the weights are getting stuck. did you get a lot of debris out of the drive clutch when you had the cover off?
09-25-2011, 03:32 PM
Member #18950
Yea, the old belt was in shreds. I took a blow gun and blew it out as best as I could.
2008 polaris phoenix, 2008 polaris phoenix 200, 2008 polaris phoenix 200 starter, atv clutch atv 200, clutch for polaris phenonix, drive belt for 2008 polaris phoenix 200, driven clutch puller polaris phoenix, how to remove polaris phoenix clutch, how to remove the belt on 200 polaris, how to replace a drive belt on a polaris 200, is polaris phoenix 200 belt driven, polaris clutch removal, polaris phoenix 200 belt, polaris phoenix 200 clutch kit, polaris phoenix belt, polaris phoenix clutch, polaris phoenix clutch kit, polaris phoenix clutch removal, polaris phoenix drive belt, polaris phoenix drive belt replacement
