Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix
Polaris Phoenix Discussions relating to the Polaris Phoenix
Old 07-23-2011, 06:12 AM
Paulcalif's Avatar
Member #5273
Battery Dead, runs but headlights dim
I rinsed off my quad lightly with water and it started running rough. After about 20 min. it started running fine again. Two days later the battery was dead. I was able to kick start it and it seemed to run ok, but the lights were dim and they did not brighten with I rev'ed it up. If this was a car, I would suspect the alternator or wet wiring/connections.
I've worked on a lot of cars, but new to quads - any suggestions on where to start?
Thanks!!
Old 07-23-2011, 08:31 AM
Which machine is it?
Edit* I just saw this was in the phoenix section. a 200 phoenix?
Old 07-23-2011, 12:41 PM
cwlongshot's Avatar
Well you don't have a alternator as your car does... You do have a stator and this basically does the same thing. but just as your car, it provides very little voltage to charge the battery at idle.
Check the connections of the battery and give it a good charge and test it. You may have a bad battery.
The motor will start and run on a dead battery, but the light will be dim or off at idle. Should brighten as the RPMs raise.
Old 07-23-2011, 04:11 PM
Paulcalif's Avatar
Member #5273
Thanks for the replies - more info.
It's a Phoenix - I'm not sure of the year, but I think it's about an 2004. I read the voltage on the battery while the engine was off, it was a little over 12V. Not enough amps to turn it over. When I kick started it, the voltage dropped to around 9V. I rev'd it and it came up to just over 12v. I disconected the battery while it was running and the voltage dropped to like 2 or 3 volts, but it did keep running. I am trying to charge the battery, but my charger is bad and the one I borrowed from a friend looks pretty cheap. So far, it's not holding a charge. I think the battery may be bad, but I would have expected the lights to brighten up while rev'ing, at least with the battery disconnected???? Town for me is 20 miles, and I don't have any transportation at the moment (my truck is FULL of construction lumber). I have a larger battery from my old WaveRaider that I could micky mouse connect for testing. Any ideas???
Paul
Old 07-24-2011, 01:48 AM
cwlongshot's Avatar
If I read correctly, your engine is trying to charge a battery that will not take or hold a charge.
It sounds like the battery is toast. Buy a new one and you should be fine.
Old 07-24-2011, 08:07 AM
Paulcalif's Avatar
Member #5273
Thanks, I think you are correct.
Tags
battery, dead, stator
atv battery dead?
atv headlights dim
atv not charging battery , head lights dim
atv polaris battery goes dead when running only
car battery seemed dead but after about 20 min its started
do atv have a alternater
do atv's have alternators
do atvs have alternators
do car lights dim when battery is dead
lights dim on atv when i rev it up
lights go dim battery dead but atv still running
lights on polaris atv go dim when driving
polaris battery goes dead still runs
polaris quad battery dies while runnin winch
polaris sportsman larger battery
quad atv battery dead
trail boss stator wet
why does the headlight go dim on my 2000 polaris
why is atv lights dim
will the headlights go on if a battery is dead
Barrery dead, no headlights. 3 Polaris Atvs ATV Repair and Maintenance 7 05-08-2011 09:39 AM
Dead battery Cobb71 ATV Repair and Maintenance 2 05-07-2011 05:04 AM
2009 sportsman battery dead bigmike5904 ATV Repair and Maintenance 2 10-09-2010 12:00 PM
replaced starter- battery cable still melting conections and dead battery mcmarkrazz Polaris Sportsman 4 09-19-2010 07:20 PM
90 sportsman dead battery erice Polaris Sportsman 0 04-26-2010 09:50 AM
