Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix
Polaris Phoenix Discussions relating to the Polaris Phoenix
Old 02-07-2012, 09:51 AM
Limoguy's Avatar
Member #23030
Phoenix carb woes
Recently bought a 2006 Phoenix and am having what appears to be a typical problem with popping back through the carb, erractic / non idle and backfiring on decel. I've thoroughly cleaned the carb internals, replaced the pilot jet, new spark plug and battery, but it still runs poorly, esp. at idle. I've gone through the other posts and concluded that this is a common problem with these machines, but could not tell what actually fixes them or if they can be completely fixed at all. How does one bypass / disable the throttle switch? Does that help these problems consistently or is there some other bit of magic I need to work on it? The dealer seems indifferent and won't give any advice, (how rare!), so any advice would be greatly appreciated.
Old 02-07-2012, 03:19 PM
Old 02-08-2012, 06:01 PM
MNS's Avatar
MNS MNS is offline
Member #17482
I have the 2006 sawtooth with similar problems. My jetting from the factory was way off. My manual said 108 main and 36 pilot. The dealer told me it should be 98 main and 40 pilot. I tried a 100 main and 40 pilot and it would not run. I kept the 100 main and went back to the 36 pilot and it was better (not good). Still have to adjust idle from cold to hot. Am I happy, NO. Machine is a major pain. I won't sell it because I don't want someone else to deal with it. Always looking for advise also.
2006 polaris sawtooth carburetor
carbburator cleaning polaris phoenix
how to adjust a polaris phoenix carburetor
phoenix bypass throttle switches
polaris carb pheonix
polaris phoenix carb adjustment
polaris phoenix carb problems
polaris phoenix carb settings
polaris phoenix forums
polaris phoenix tune
polaris quad sawtooth won't idel
polaris sawtooth carb schematics
polaris sawtooth clean carburetor
polaris sawtooth problems
problems with the polaris sawtooth 2006
tune a polaris sawtooth carb
tuning polaris phenix
Atp 330 woes whiskey ATV Repair and Maintenance 0 05-06-2011 06:48 PM
clutch woes dublduty ATV Repair and Maintenance 3 03-15-2011 01:33 AM
2000 Sportsman 500 Starter Woes Johnny Reb Polaris Sportsman 9 01-17-2011 03:44 PM
550 xp oil and filter change woes waynev Polaris XP 8 11-24-2010 06:33 AM
front end woes zzoomz` Polaris Sportsman 1 07-03-2010 08:29 AM
