Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix
Polaris Phoenix Discussions relating to the Polaris Phoenix
Old 06-05-2010, 02:46 PM
Paulcalif's Avatar
Member #5273
Help! Did I get ripped off? What is normal Compression?
So our "new to us" 06 Pheonix is misfiring. I pulled the plug and it's black. I checked the compression and I believe it's only 70PSI (my compression checker has seen it's better days).
What is normal compression on these?
Old 06-05-2010, 03:13 PM
Paulcalif's Avatar
Member #5273
Update ---
Oops - Checked with throttle closed. With it open I get over 120! Yippy
It runs better with a new plug BUT sitting in neutral and reving it, it does not rev up all the way. Is there a limiter kicking in when it's sitting still?
Thanks for any input
Paul
Old 06-05-2010, 04:39 PM
3 Polaris Atvs's Avatar
Member #1102
Sounds like you need to clean the carb.
1998 Scrambler 500 HO 4x4
1995 Scrambler 400 4x4
2000 Trailblazer 250 2x4
Sportsman 90
1998 Sportsman 500 4x4
Old 06-05-2010, 08:59 PM
Paulcalif's Avatar
Member #5273
You may be right!
I am thinking the same thing. But before I do, I am going to drain some oil. There is too much in the crank case, it's above the top of the sight glass. The plug was fouled really bad, and the air filter was dirty. Also, there was a ton of OIL under the filter in the housing. Not sure what that means, but it can't be good. Possibly from too much oil in the crank case???
Thanks for the advice!
Old 06-05-2010, 09:52 PM
Member #1102
Too much oil could be gas and oil. Change it,
Sportsman 90
Old 06-06-2010, 06:31 AM
The Kid's Avatar
Member #3743
sounds like the float stuck in carb and flooded the crankcase
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
Old 06-06-2010, 09:36 AM
Paulcalif's Avatar
Member #5273
Pulled the wrong drain plug!
Doh! I downloaded a copy of the owner's manual, but I'll be damned if I could find a good description of which plug was for draining the oil and which was for the trans. Of course I picked the wrong one! Drained the trans. Fortuately I used a new container and had wiped off the area around the drain plug really well, so I poured it back in (I'll change it soon). There is only a little bit too much oil in there because when I shake the bike I can see the top of the oil in the sight glass. There was to much trans fluild too, so I am hoping that who ever filled them last just over filled them. But the stuck float is certainly a possibility and one I hadn't thought of. I see two drain plugs. The trans has a regular bolt type head, the other is an Allen or hex type. I don't have an allen that big. I tried using a lag bolt and a pair of vice grips but the bolt twisted and broke! I'll look for a machine bolt today and try again. Can I get a filter at an auto parts store? And what kind of oil are you guys using? Are you sticking with snythetic and if so, then Mobile 1 ok?
Paul
Old 06-06-2010, 09:39 AM
Member #1102
I use Mobil 1 and change it once a year.
Sportsman 90
Old 06-06-2010, 09:42 AM
Paulcalif's Avatar
Member #5273
Do you buy your filters at the dealer? I just search the Fram site and they list polaris but no Pheonix. I use Mobile 1 in my car, cheaper at Costco. Thanks - I will do the same.
Old 06-06-2010, 09:51 AM
Member #1102
I buy mine at Napa
Sportsman 90
1995 polaris scambler 400 compression
2000 polaris trail blazer compression
2001 polaris scrambler 400 compression test
2001 polaris sportsman 400 flooding
2002 polaris ranger 425 engine compression
2002 polaris sportsman 500 compression
99 scrambler misfire
compression on scrambler 500
how much compression does a 2000 polaris trail blazer have
how much compression for 400 scrambler
how much compression should a 2001 polaris 250 trailblazer have
polaris 120 compression
polaris 400 scrambler fan in orange county
polaris gas in oil
polaris scrambler 500 compression
polaris sportsman 400 compression
whats the compression supposed to be on a polaris scrambler 500
why wont polaris phoenix rev up
Low compression Mitchell Polaris Sportsman 2 04-29-2010 10:30 AM
Compression Stevehi Polaris Trail Blazer 2 04-17-2010 02:19 PM
No compression chewy1010 ATV Repair and Maintenance 1 10-29-2009 08:52 AM
Loud whine. Normal or no???? XJCraver ATV Repair and Maintenance 12 08-20-2009 08:05 AM
Is this normal ? Jamieg ATV Repair and Maintenance 2 08-04-2009 09:56 AM
