Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix
Polaris Phoenix Discussions relating to the Polaris Phoenix
Old 10-30-2010, 10:04 AM
j.h.'s Avatar
Member #8667
Question runs for while then dies
I have a 05 phoenix 200. starts up runs fine, after a while it dies sometimes backfiring. I've tried a different rugulator box, sparkplug, coil wire, and a new cdi box with no luck. It will run for a few minutes after it sets, but same thing over and over again. It will also set and idle all day, but when you hit the gas to take off it dies. any suggestions.
Old 10-30-2010, 12:38 PM
Old 10-30-2010, 01:20 PM
Manaen's Avatar
Member #6699
did you check to make sure you have good fuel flow to the carb? you could have a plugged petcock or fuel filter which flows enough to fill the carb bowl but not enough to keep up with the running engine.
What made you think it was an electrical problem? does it spark if you pull the plug and crank over after it dies?
Old 10-30-2010, 01:33 PM
Manaen's Avatar
Member #6699
BTW double post is a big NO NO
Mods can you kill other thread.... runs for while then dies
Old 10-30-2010, 01:43 PM
j.h.'s Avatar
Member #8667
mechanic said wasn't getting fire when hot so I believed him. pulling carb. of first thing morning. thanks..
Old 10-30-2010, 06:14 PM
Manaen's Avatar
Member #6699
that's possible, and many times electrical parts fail like that. However a simple spark test will tell the tail. I hate throwing parts at things without running through all the diagnostics. always start with the simple stuff. If a motor doesn't run check the big three..
1) compression
2) fuel (in the right amount)
3) spark (at the right time)
how long does your engine run before cutting out? and does it just shut off, or sputter and then finally die?
4 wheeler runs then dies out
4 wheeler starts but dies
4wheller cranks then stalled
atv runs fine then stalls sometimes when i give it gas
engine run a while then dies
four wheeler cut off while riding
four wheeler runs and quits
four wheeler runs but shuts down
four wheeler will crank and run but then cut off
my 4 wheeler atv starts to sputter after 10 minutes
my four wheeler just cuts off while running
my four wheeler starts but then dies
my polaris sportsman atv sputters and shuts down after 20 minutes of riding it
polaris idles fine but dies after ridin it
polaris phoenix 200 starts but wont idle
polaris phoenix idles and cuts out
polaris phoniex 200 spark cutting out
polaris stalls after a few minutes
polaris starts runs
quad runs rough then shuts down
runs for while then dies j.h. Polaris Phoenix 0 10-30-2010 10:02 AM
800 touring runs rough jerry1230 ATV Repair and Maintenance 1 09-28-2010 05:45 AM
96 explorer 400 4wd runs rough abronfuller ATV New Members 1 10-11-2009 05:25 PM
500 runs and quits LMAC Polaris Sportsman 2 09-27-2009 12:27 PM
key still runs cookieduster Polaris Sportsman 3 06-01-2009 06:31 AM
