I have been working on my pred for a while now, I let it sit for about two weeks after i changed the oil and filter, before I tryed to start it I found the battery to be dead so I charged it and tryed to start it again. When I clicked the starter button all I herd was a little ticking down by the battery but not from the battery. DOES ANYONE KNOW WHAT THIS IS????at:
you might check the starter relay under the front left fender near the coolant reservoir. It's usually zip-tied to the frame and is covered in a black waterproof plastic cover. I had the same problem a while back. The part is like 40 dollars through polaris. If it's not that, your battery is probably bad. They can fool you by holding a charge, but not putting out enough amps to turn the starter
113.2K members
