Old 04-10-2011, 06:15 PM
Ta2edphreak's Avatar
Member #13890
hello to everyone
well this is the first post ive made, today i purchased a 2003 predator 500, full yoshi system, k&n air filter, jetted. for 1600. the only thing it seems to need is a front sprocket, anyone know what size is in the front? i had a 350 raptor prior to this, how are the 500 predators? seems like a beast of a machine to me, and the pipe sounds really intimidating...thanks in advance boys.
File Type: jpg 3k13o63p85Z45W25S1b4954150905ae751bc7.jpg (7.5 KB, 9 views)
Old 04-10-2011, 06:33 PM
racer37l's Avatar
Member #5629
Welcome!
The sprocket you need is a 14 tooth, Polaris part# 3088132. Does the tooth count sound right? 'cause the partfiche just said predator no mention of a 500cc.
Good luck and hope you enjoy your new bike.
Con
Old 04-10-2011, 06:39 PM
Predasaurs's Avatar
Member #10140
welcome and its a 14 tooth as mentioned above
Old 04-10-2011, 07:16 PM
jordaman17's Avatar
Member #13240
welcome!
Old 04-10-2011, 07:34 PM
chopper89's Avatar
Member #1634
welcome to the forum
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 04-11-2011, 07:33 AM
Member #13890
what is involved in changing out the front sprocket? is it an easy thing to do?
Old 04-11-2011, 01:35 PM
Predasaurs's Avatar
Member #10140
two 8mm bolts and it just slides off ( theirs a guard but that's two bolts as well)
and have to pop the master link out of the chain..
but when i change a sproket i change it all so it all wears evenly
chain and the two sprockets
Old 04-11-2011, 02:24 PM
Member #13890
well the rear sprocket looks ok i dont know about the chain, but the front sprocket is starting to cup pretty good, do all chains have a master link? how do i check the chain?
Old 04-11-2011, 03:10 PM
Predasaurs's Avatar
Member #10140
yeah they have them , or else wouldn't be able to put it on threw frame (pic below of master link)
as for the chain on the rear sproket pull one of the links from the rear sproket and if it pulls more than 1/2 the height of the rear tooth its excessive worn .
or measure any 20 links (21 pins) span , the pins from center to center, if its more than 327mm (12.87) inches its worn
check the inner chain plate faces they should be evenly polished on both sides, and if their is uneven wear then the sprockets aren't aligned properly , kind of hard to type it out but if u have any questions about a step ill go into further detail
Old 04-12-2011, 02:23 AM
redneck2725's Avatar
Member #3177
14T is the stock size, alot of guys drop it to a 13T for more low end power. Also, check out the chain. If it might need to be replaced soon, just do it before you are stuck somewhere. Can find a good deal on Rocky Mountain ATV, where i bought mine from.
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
3088132 polaris
max tire size for 2008 polaris sportsman 500 efi
