04-11-2011, 04:09 PM
Member #13890
suspension setups?
i have an 03 predator, full yoshi system, jetten and a k&n filter, when i get on it the front tires come off the ground about a foot, i have the stock fox podium shocks, is there any way to adjust them so the front tires dont lift? ar at least as much?
04-11-2011, 04:15 PM
There is some suspention that will help with this, but I'm thinking body position would do more...
If your rear suspention is too stiff, you may get a bit of front end lift. Maybe try softening it... Other then that, I say, get some extra weight, yours, farther forward.
04-11-2011, 04:24 PM
Member #13890
i just bought the machine yesterday, used, what is the adjustment for the rear shock? lower number is stiffer or softer? im about 260lbs, my weight was just on the seat sitting as normal?
04-22-2011, 12:25 AM
Member #4423
If you keep an eye on ebay, every once and a while a used extended swing arm will pop up. I got a +4 for $50.
adjusting fox shocks on 03 predator, adjustment on fox podium shox, atv front suspension setup, can your atv suspension be to stiff, fox podium suspension for 04 polaris predator, fox shocks tuning atv, how can i extend the struts on my polaris, how do i ajust the shocks on my 03 polaris preditor, how to adjust fox podium shocks, how to adjust polaris predator foxx shocks, polaris predator front fox shock how to adjust, polaris predator front shock adjustment, polaris predator front suspension upgrade, polaris predator shock adjust, polaris predator shock adjustment, polaris predator suspension setup, polaris suspension setup, predator podium forum, stiffer springs for polaris predator, what should predator shocks be at for my weight
