Old 04-12-2011, 02:19 PM
Liquid2500's Avatar
Member #13956
How to jet my 500?
I have 2005 Polaris Predator 500 Troy Lee edition. I just put a hmf slip on exhaust on, also I have closed air box with a push in k&n air filter. I mostly ride in the coal region in south east Pa, usually about 70 degrees. What jets should I use in my quad??
Old 04-12-2011, 02:25 PM
eleaglesrock's Avatar
Member #12922
i would recommend 160 main jet. its a 150 main jet stock extra 5 for exhaust and 5 for airfilter
Old 04-12-2011, 04:09 PM
Old 04-12-2011, 06:00 PM
Liquid2500's Avatar
Member #13956
Thanks, now would a 160 be good at 500ft of elevation? I also heard I could go with a 170. Now what happens if I go too high or too low?
Old 04-12-2011, 06:17 PM
Member #12922
I'm at about 575ft above sea level and the 160 works very well. Nothing bad would happen if you had the wrong jetting, you would lose some power and you would hear some popping sounds on deceleration. If you expirience any of those issues or if the engine seems to cut out, you're jetting is not right
Old 04-13-2011, 04:40 AM
Liquid2500's Avatar
Member #13956
Thanks. What pilot do you run and where should I run the clip?
00 polaris 500 stock jetting
2005 polaris predator 500 jetting
2005 polaris predator stock jetting
best jet for predator 500
hmf jet kit for polaris predator 500
hmf pipe predator 500 recommend
how to jet a polaris predator
how to jet a polaris predator 500
pilot jet polaris s
polaris pedator main jet sizes
polaris predator 500 main jet
polaris predator 500 main jets
polaris predator main jet style
polaris predator stock jet size
polaris predator stock main jet
predator hmf jetting
predator slip on jetting
stock jet polaris preditor 500
stock predator 500 pilot jets
what's the main jet size in a polaris predator 500
