04-13-2011, 07:22 AM
Member #13977
03 Predator - Stuck in gear - Wont start
I recently bought a 03 Predator from a guy. He said he was driving it and it stuck in 3rd gear. So he shut it off and now it wont start. (clutch in or out) I jacked the rear end up and jumped across the starter solenoid and it has compression and will turn the rear wheels when doing this. Although i do not have spark when doing this. I guess i am unsure of what to tackle first.....starting issue or trans issue. OR is it that being stuck in gear, wont let me start??? Is there a way to by pass the neutral safety??? Any ideas or help on this would be GREATLY APPRECIATED!!!
04-13-2011, 09:33 AM
04-17-2011, 06:53 AM
Member #9885
I would start by trying to get it out of gear. Have you changed the oil? What weight of oil is in it? Also, is the clutch working, does it disengage the drive sprocket when pulled?
"The rippin and the tearin"
04-17-2011, 11:04 AM
Member #10140
u can start it in any gear ( clutch in ofc) transmission issue in my opinion
04-19-2011, 05:41 PM
Member #13071
loose shift drum?
03 polaris predator 500 shift drum, 03 polaris predator 500 shifter gets stuck in 3rd gear, 03 polaris predator shift drum, 125 baja quad stuck in gear wont start, 3rd gear out polaris predator, atv gets stuck in second or third gear, atv stuck in gear, atv turned off in gear wont turn back on, my four wheeler is stuck in gear, my polaris atv is stuck in gear how do i get it out, no third gear on polaris preditor, polaris predator 500 starter gear, polaris predator 500 wont start does not get the neutral light, polaris predator stuck in 1st gear, polaris predator stuck in gear, polaris predator wont shift out of first gear, predator 500 gears gets stuck, predator 500 gears wont work, predator 500 stuck in gear, predator shifters
