04-14-2011, 01:55 PM
Member #13890
blue rear shock dial
i have a 2003 500 predator, anyone know which way does what for the blue dial that adjusts it? im 250lbs. I ride in the woods, no racing or anything...just hard woods riding. any information would be appreciated. thanks!
-Ta2edphreak-
You can also find me on Xbox Live, same name, spelled the same.
04-15-2011, 04:19 PM
Member #12642
Hope this helps
04-16-2011, 07:28 AM
Member #13890
where are the compression and rebound adjstments?
04-16-2011, 07:40 AM
Member #12642
You'll need to compress the spring more, loosen the first nut and then tighten the second adjustment nut down.
03 polaris predator 500 fox racing strut adjustment, 2003 polaris scrambler rear shock, 2003 predator 500 suspension settings, adjust shocks on polaris 500, best setting for rear shock on 500 predator, blue rear shock, harder rear shock polaris 2010 scrambler, how to adjust fox racing rear suspension on a polaris predator, how to adjust rear shock predator, how to adjust rear suspension predator 500, how to adjust scrambler 400 4x4 adjustable fox rear shock, how to ajust rear shocks polaris scrambler, how too adjust shocks on a 2000 polaris 500 scrambler, polaris 400 shock adjustment tool, polaris predator 500 rear shock adjustment, polaris predator rear shock, polaris scrambler adjustable fox rear shock, predator shock adjustment, predator shocks settings, rear spring removal on polaris scrambler
