Old 04-16-2011, 10:26 AM
boostntoy's Avatar
Member #14013
predator basket case
i bought a 2003 polaris predator, not running. It would run when it was bump started but not start on its own. After pulling the starter clutch i found that was bad because it would only engage sometimes. Checked the valves and they are way too tight to be within specs. Adjusted the valves and then did a compression test on it. The problem I have now is the compression tester read at least 250, a couple different times. What could be the reason why the compression is reading so high? Could a cam be wiped out? I believe the motor has a high compression piston in it but dont know anything more about it.
Old 04-16-2011, 11:17 AM
Old 04-22-2011, 01:15 PM
boostntoy's Avatar
Member #14013
Really? Nobody? I pulled the cams and the decompression release on the exhaust cam seems as though it is not as tight as it should be. I have new cams coming but I am afraid that is not going to cure the problem. I know there is someone out there who knows.
2003 polaris predator clutch basket removal
2003 polaris predator compression
2003 polaris predator compression spec
case for a polaris predator
clutch basket removal predator 500
compression ratio of 2003 polaris predator 500
polaris atv baskets
polaris predator 500 cam compression release
polaris predator compression release
polaris predator compression release adjustment
polaris predator compression release problem
polaris predator exhaust cam picture
polaris predator why is cam advanced
polaris+compression+release adjust
predater 500 compression release
predator 500 where is the compression release
predator exhaust camshaft
repair polairs preditor exshaust cam
which polaris predator cam has the compression release on it
OIL IN PVT Case - Now what ?? hippy_dave ATV Repair and Maintenance 6 02-15-2011 06:54 AM
2009 Sportsman 500 HO Metal Rack Basket bradj63 2009 1 12-20-2010 03:39 PM
Splitting of the Case Apgar57 Polaris Predator 0 07-29-2010 05:17 PM
WTB transmission or case ad2tude ATV Parts for Sale 3 05-18-2010 08:13 PM
Polaris explorer 300 basket case steveo ATV Repair and Maintenance 23 01-20-2010 03:41 AM
