Old 04-17-2011, 05:03 PM
yahookingjoe's Avatar
Member #14118
04 Predator 500, Engine trouble.
I have an 04 predator 500. The engine starts, then pops, and seems to seize up. It will start up again, but it seems as soon as it heats up it dies again. If in the lower RPM's, it will die almost immediately. I don't want to run it more than I have too.
Does anyone have ideas?
Old 04-17-2011, 07:48 PM
Old 04-18-2011, 04:12 PM
Member #14118
Thanks for the welcome.
Does anyone have any ideas?
Old 04-19-2011, 03:31 PM
joshr08's Avatar
Member #13071
mods? history on the bike? your not giving us much to go by. what were you doing when it happened the first time?
Old 04-19-2011, 04:04 PM
Member #14118
It's stock all to the bone except a new set of tires and rims. It wasn't ridden much. 4th gear was gone when we baught it. Wasn't that big of a deal, and it enabled us to get it cheap. It ran fine, had a little top end noise when it first starts, once warm it's gone.
A friend was on it the first time it quit. I had thought the battery went dead (we were having charging issues, but we did fix them, just a shorted wire) So I jumped it with my Jeep, then went to go. It quit about a minute or so later, wouldn't turn over. Thought the engine was gone right then. Got it back to house, and tried again and it fired right up. No extra noises or anything. After about it a minute it kinda squeaks, then quits.
Anytime I try to get it to go now, same deal, only tried twice since, don't want to do any more damage. The oil was low, but still on the stick. The oil was recently changed not long ago.
It was transported about 2600 miles from home. I think it was standing up most the of way. It did however sit for about a week before I fixed the wiring and fired it up.
Old 04-19-2011, 05:00 PM
joshr08's Avatar
Member #13071
first timing, second valves or clearances, third bad cdi or the black bag circuit. or it could even be maybe as simple as lean jetting to the extreme like a plugged main jet or stuck needle hole in the carb slide diaphram
Old 04-20-2011, 08:29 PM
Member #14118
Well the quad came from about 300' elevation, and I'm now in 3800'.
Could that cause the problems?
Old 04-21-2011, 12:39 AM
joshr08's Avatar
Member #13071
could be i guess
Old 04-23-2011, 11:08 PM
PREDATORx23's Avatar
Member #14301
This will most likely be a stupid suggestion but do you have the gas turned on?
I only suggest this because it got me earlier today. I took my bike out and forgot to turn the little lever and was sorta having the same problem you are describing.
Old 04-24-2011, 02:16 PM
mk2turbo's Avatar
Member #13458
I'm glad I'm not the only one that has done that. My bike died, kept hittin the starter, started freakin out, then my wife comes over and turned the gas on. That's why I love her!
03 polaris predator knocking
04 polaris predator 500 noise in the motor
04 predator 500
04 predator 500 noise coming from engine
polaris 500 engine noise
polaris predator 500 engine
polaris predator 500 engine knock
polaris predator 500 engine noise
polaris predator 500 motor
polaris predator 500 starter problem
polaris predator 500 starts but locks up
polaris predator engine knock
polaris predator engine noise
polaris predator locking up
polaris predator motor problems
predator 500 engine problems
predator 500 motor
why does my polaris preditor 500 knock
07 outlaw 500 engine trouble fastoutlaw69 Polaris Outlaw 2 09-26-2011 06:58 PM
predator engine fngboy Polaris Predator 2 02-27-2011 06:17 PM
1994 Polaris 350 engine trouble clerihew82 ATV Repair and Maintenance 3 11-18-2010 06:30 PM
02 predator 90 carb trouble ?? GRUMP ATV Repair and Maintenance 3 10-03-2010 10:27 AM
Polaris Predator engine yzryder125 Polaris Predator 3 08-21-2010 04:07 PM
