Old 04-18-2011, 10:38 AM
Predator_03's Avatar
Member #13522
03 Predator wheels sit inward from the top. Need Help!!!
hey everyone, im having a probelm with my 03 pred. both wheels sit inward. the right side sits inward really bad and the left side you can barely tell. Now i checked the A-arms and they dont seem to be bent. I cant figure out any solution to the probelm. any help is appreciated.
Old 04-18-2011, 02:27 PM
Predasaurs's Avatar
Member #10140
ok so something musta bent if it wasnt always like this , same thing has happened to me . mine ive had bent steering stems a arms or tie rods , so ive always just put it back to normal.
your frame may be bent aswell . but quick fix is adjust the tie rods to that the tires are toed out 1/4 inch.
i just measured ( with rider weight on the bike) the same height up on the tire for front and back and measure across so they should look like this
\ / ( but not such steep angle just 1/4 inch)
Old 04-18-2011, 04:16 PM
Member #13522
thanks i did that and it helped out a bit i found out what the major problem was. the spindle was slightly bent.
cant fix bent tire 03 preditor
front wheel bent in on my predator help
front wheel bent in on my preditor help
polaris predator 500 front tire bending
polaris predator 500 one front tire bent
polaris wheel inward
tire on atv bends inward
why is my tire sitting inward
will polaris a-arm bend before the frame bends?
WTB Wheels and/or Wheels and Tires 02 Scrambler 500 .. 10x8 / 4x4 bolt pattern digger357 ATV Parts Wanted 4 06-20-2011 07:40 PM
will the ss112 wheels fit my 2003 polaris predator 500 durst2020 Polaris Predator 5 02-28-2011 12:27 PM
Trad me 09 850xp wheels for My 2010 14inch aluminum wheels Quad Master ATV Wheels & Tires 1 09-05-2010 08:26 PM
Trade 2010 850xp eps wheels for 2009 wheels Quad Master ATV Parts for Sale 1 09-05-2010 08:18 PM
Predator rear wheels question peete46 Polaris Predator 1 08-10-2010 05:11 PM
