04-19-2011, 02:36 PM
Member #14183
Running ethinol in your predator
I was wondering if anyone has ran or know if you can run e85 in the predator.
If so did you have to re jet it or use a fuel additive?
Or can you mix it 50/50 with gasoline.
And if. used will it hurt you motor.
04-19-2011, 02:52 PM
Member #3442
A couple of the guys i ride with have their 450r's running on E85. They just changed the jets, no fuel additives and only E85 from the local gas station (not 50/50). i want to do the same to my pred, so let me know how your making out
04-19-2011, 03:38 PM
04-22-2011, 05:48 PM
Member #13458
It shouldn't be a problem. You would def need to rejet as e85 doesn't have the same amount of energy per unit as gasoline but the octane rating is higher. You could run more timing for sure.
04-23-2011, 01:40 AM
This stuff is going to be death to small engines!! Unless you run it daily and run the fuel system dry every time, you WILL HAVE PROBLEMS!!
Just last night I ran across a Lucas Oil product specifically designed to combat the negative aspects of running 85% Alcohol (E85) fuel.
I strongly suggest ALL people running it begin using a good additive like this to combat the negative aspects of this fuel we will all soon be faced with using...
04-23-2011, 06:24 AM
Member #13458
I don't know about the death of small engines  , but an additive isn't a bad idea. It is a gummy fuel if left to sit, some teflon fuel lines will help but the carb will suffer if not looked after.
E85 is used extensively in Europe, especially in high hp turbo cars. The octane rating is somewhere around 110 which allows you to run a lot a boost(turbo pressure) and advanced timing, making moar hp! I used to be into Saab turbo cars and there are quite a few tuners that use E85 exclusively, 500 hp on pump gas is nothing to sneeze at. Unfortunately, there is only one station in MA that has E85 and it's at the airport, an hour away.
03 polaris predator 500 on e85, alcohol carbs for polaris predator four wheeler, can i run e85 4 wheeler, can i use dry gas in my polaris 4 wheeler, can u run ethanol in atvs, can you run e85 in a atv, does a preatdor 50 use mixed gas, e85 4wheeler, e85 additive, e85 polaris, ethinol, fuel additive polaris predator, polaris 4weeler 50cc predator, polaris predator carbs set up for alcohol, polaris predator e85, polaris predator gas mix, predator carb e85, predator carb for e85, running e85 with a predator carb, will predator engines run on e85
