04-21-2011, 08:53 AM
Member #14250
Rear Shock adjustment trouble
I have read through a number of posts, and understand how to adjust the rear shock, however on mine the dial will not turn. It is in the number 1 position currently. Do you need to loosen the allen key in the centre to allow it to move or should just turning the dial be enough?
04-21-2011, 10:41 AM
04-21-2011, 03:45 PM
Member #13071
you just have to turn the dial so i would say it hasnt been messed with in a long time. spray it with some type of penetrating oil i like PB blaster myself but anything thats mad to penetrate should work let it sit for a few mins and then try turning it. You may end up having to buy a new one or take yours in and have it serviced if that doesnt work.
04-21-2011, 04:20 PM
Member #13545
Welcome to the forum!! What bike ya got?
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
04-21-2011, 04:24 PM
Member #13968
Make sure you jack your bike up from under the hitch part of it so the tires drop down and you take all the pressure off the spring. Once you do this, put your shock wrench on and make sure you have it seated well, then give quick powerful presses on it to get the adjustment block to move.
UTG
2011 Polaris Sportsman 850 XP EPS Black
ATV-Guru Cobra Series Front & Rear Bumpers
The ATV Superstore 3 in 1 Hitch
The ATV Superstore 3 light HID Kit
WARN XT30 Wireless Winch
Ricochet Ultimate Armor Skid Plate Kit
Hatchie Bottoms Neoprene Camo Seat Cover
ITP SS212 Blacks w/ GBC Spartacus' 27" @ 5 psi
Speedwerx "Hot Seat" Slip-on Exhaust
Hypershift Clutch Kit
Future Items:
Power Commander V
04-21-2011, 04:37 PM
Member #3985
Use Pipe Wrench
I have had success using a Pipe Wrench with the Teeth Wrapped in cloth so as not to damage the finish.
Working it back and forth. With Weight off.
2006 Sportsman 500 EFI ( Green )
MODS:3 Light Mod, HID Lighting Upgrade, Front and Rear Bush Guards, Body Armour Fender Protectors, JamHard Rad Guard, Polaris Hand Guards, Front Rack Extender, Kimpex Rear Box, Handlebar crossbar for accessory mounting, Garmin extex legend GPS, UNI Air Filter, Rear Foot Pegs, Glacier II Plow System.
04-21-2011, 05:50 PM
Member #13071
im pretty sure he has a predator and is talking about the adjuster on the ressie bottle. i could be wrong tho.
2011 ranger 800 efi how do u adjust the front shocks youtube, adjusting polaris ranger suspension, adjusting shocks polaris ranger, adjusting the suspension on a 2011 polaris ranger xp, how do you adjust the rear shock on a polaris, how to adjust rear shock on atv, how to adjust rear shocks on atv, how to adjust shocks on polaris ranger, how to adjust the rear wheels of a polaris ranger, polaris 2008 500 ranger rear shock adjustment, polaris predator rear spring shock upgrade, polaris predator shock adjustment, polaris ranger 800 rear shock adjustment, polaris ranger crew shock cam adjustment, polaris ranger shock adjustment, polaris ranger suspension adjustment, polaris shock adjustment tool, predator 500 recommended suspension settings, shock adjustment for polaris ranger, shock adjustment polaris ranger
