Old 04-24-2011, 08:16 AM
KDIESEL's Avatar
Member #14354
Burning oil
Just bought a 03 pred. Yesterday. Did a pretty good check over on it before I bought it. Battery was dead so I had to jump it. It hadn't been ridden in a year. Very very clean quad. When running before I took it it ran clean. So I got it home. Put it on the charger. Checked all the fluids and gave it a once over. Oil was low so I added some. Started it and now it smokes and smells like oil burning pretty bad. Haven't even rode it yet. Talked to a few people. Checked the spark plug. Looked fine. Not fouled. So I decided to ride it around to see what happened. It burned up half a quart in a hour. Any advice. What would be the fix and about how much. Thanks for all the help.
Old 04-24-2011, 10:27 AM
joshr08's Avatar
Member #13071
you will need to do a compression test to see if its coming up past the rings or coming down from the head thats the only two ways oil will get into the combustion chamber. valve guides could be wore or rings are bad.
Old 04-24-2011, 05:21 PM
500 sportsman burning oil
atv burning oil and smoking
light white smoke on polaris 500 ho
oiling system on polarse ranger 500
poalris sportman smoking
polaris 500 burning oil
polaris 500 smoking
polaris 500 sportsman smoking
polaris predator 500 burning oil
polaris predator 500 smoking
polaris predator burning oil
polaris ranger 800 smokes
polaris ranger burning oil
polaris ranger losing oil
polaris ranger smoke
polaris sportsman 500 burning oil
polaris sportsman 800 burning oil
predator 500 smoke bad
what to do if polaris sportsman 500 h.o. smokes smell like oil
2010 850 XP - Oil Burning Issues davistitle Polaris XP 7 09-01-2011 08:10 AM
white smoking burning Antifreeze bowhunter1824 ATV Repair and Maintenance 4 02-01-2011 07:34 PM
Trailboss 325 keeps burning out headlights stonekn ATV Repair and Maintenance 1 02-10-2010 02:12 PM
1800 miles and burning oil 03 500HO Polaris Sportsman 3 11-26-2009 08:01 AM
Burning Belts.... smore79 ATV Repair and Maintenance 5 08-06-2009 08:10 AM
