I agree with the other guys, the Pred runs hot. As long as it is not overheating, then should not be an issue
The brakes could be several things, i have a major issue with mine, replaced quite a few parts for nothing, and found out my caliper was hanging up. I would start there, take the caliper off and manually push it in with a c-clamp, then pump the brakes to make it expand. Do it a few times, might be the issue.
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
