Old 04-26-2011, 08:24 PM
Predasaurs's Avatar
Member #10140
new battery
hello looking for some opinions on a good battery brand/ kind
i need something with more cranking amps than the stock battery
ive been told gel cell but not sure what brand
07 predator 560cc
Old 04-26-2011, 08:34 PM
LEOGM5150's Avatar
Member #14419
here are 3 good options
Batteries - Golf Cart - Marine - Deep Cycle - Motorcycle - RV - Powerstride
WPZ14S Fits Honda Motorcycle Models VT750DC Shadow Spirit (2001-2006)
Volts: 12
CCA: 250
Ahr: 11.2
Length in.: 6.00
Width in.: 3.43
Height in.: 4.38
Weight Lbs.: 8.8
Chemistry: AGM
BOMBARDIER Outlander 800 EFI ATV Battery - WPX20L-BS
Our Products: Motorcycle ATV & Utility Vehicle Batteries > BOMBARDIER/CAN AM ATV Batteries
View a larger version of this image
SKU: PS01-352
Weight: 15 lbs
Compatible with OUTLANDER 800 EFI 2006
Volts: 12
CCA: 310
Ahr: 18
Compatible with Bombardier/CanAm 650cc DS650 2000-2006 Models
Volts: 12
CCA: 300
Ahr: 13
Length in.: 6.88
Width in.: 3.25
Height in.: 5.06
Weight Lbs.: 11.5
Chemistry: AGM
2007 OUTLAW 525 IRS
2005 TLD PREDATOR HOT SEAT 600
2003 PREDATOR 500
2001 400 TWO STROKE SCRAMBLER
PLUS A DOZEN OTHERS...
Old 04-26-2011, 08:40 PM
LEOGM5150's Avatar
Member #14419
i also have now and in the past used a good oddessy battery in the predator. i have it in my 2005 polaris predator tld with the hot seat 600 predator and it works great. in the past i had it in my 2005 558 predator also and it was a great battery.
2007 OUTLAW 525 IRS
2003 PREDATOR 500
Old 04-26-2011, 08:44 PM
LEOGM5150's Avatar
Member #14419
Batteries - Polaris 500 PREDATOR 500 (2003) replacement battery
Product ID: 000A804
Amps: 200
Cranking Amps: 200
Cold Cranking Amps: 100
Voltage: 12
Termination: FEMALE BRASS W/M4 BOLTS
Chemistry: PURE SEALED LEAD ACID
Color: BLACK
Weight: 5.9
Width: 3.3900
Length: 5.4300
Height: 3.9800
PC 310 Specs:
310 cranking amps for 5 seconds
250 cranking amps for 10 seconds
225 cranking amps for 20 seconds
200 cranking amps for 30 seconds
8 Ah
Short circuit current over 455A
9 minute reserve capacity with 25amp load
CCA - 100 (Is this important?)
Length 5.43"
Width 3.39"
Height 3.98"
Weighs 5.9 lbs
http://www.odysseybatteries.com/battery/pc310.htm
this is the one i have and i like it a lot. i am on my second gel battery in my 2003 predator 500. i am not too crazy about them the oddessy battery outlasts it by 2 or 3 times as long.
2007 OUTLAW 525 IRS
2003 PREDATOR 500
2003 polaris predator replacement battery autozone
2006 polaris sportsman efi battery size
change battery in 2007 polaris outlaw
fitting an odyssey battery in a 2005 polaris 500 sportsman
how many cca battery for a polaris atv
how many cca for the wpx30cl-bs
how many cold cranking amps does it take to crank up a 2001 bombardier ds650
how to change a battery in a 2001 polaris sportsman 500
how to replace the battery for polaris predator
odyssey battery polaris sportsman forum
polaris 400 battery
polaris 600 battery
polaris atv battery
polaris atv battery cold amp
recommened battery amp for 2003 polaris 500 predator
what cca battery do i need for 2003 polaris sportsman?
what is the highest cold cranking amp battery for polaris 2001 sportsman atv
what kind of a battery does a predator 500 need
what size battery do i need for my extreme quad
what size battery do i need for my polaris predator quad 2003
Need Battery jeffofie Polaris Sportsman 12 04-02-2011 06:36 AM
Battery and 4x4 jseamans1022 ATV Repair and Maintenance 2 03-18-2011 06:45 AM
new battery macdaddy Polaris Sportsman 2 01-07-2011 12:05 PM
replaced starter- battery cable still melting conections and dead battery mcmarkrazz Polaris Sportsman 4 09-19-2010 07:20 PM
04 Polaris Sportsman 700- Battery cable melted battery?? clarksofky Polaris Sportsman 3 12-24-2009 06:45 AM
