Old 04-27-2011, 05:59 AM
TheBatJon's Avatar
Member #13181
Suspension Help
Alright so I took the Pred out to Durhamtown and realzied that my suspension (mainly the front) bottoms out way too easily. Even in the smallest of jumps and bumps I would hear metal hit metal. What part of the suspension setup do I need to adjust to keep this from happening?
Old 04-27-2011, 07:27 AM
crimson850's Avatar
Member #5005
Sounds like they need to be revalved and rebuilt.
2010 Polaris 850XP LE crimson red edition.-TOTALED
Pure polaris front and rear deluxe brush guards.
Pure polaris front and rear a arm guards.
Pure polaris lock & ride tall windshield
Pure polaris lock & ride gun scabbard
Pure polaris steel rear rack extender
ITP terra cross tires
Maxxis RAZR 4 speeds
UNI air filter
oury grips
RATH racing pre runner style chromoly bumper (front)
Ricochet Skid Plate (chassis)
Hot seat performance hypershift clutch kit
SSI decal kit
Powermadd handguard factory rider.
For any of your performance needs I would go with only Hotseat performance. I dont work for them just love there GREAT service and their amazing products[/SIZE][/SIZE][/SIZE]!
Old 04-27-2011, 07:45 AM
TheBatJon's Avatar
Member #13181
That sounds expensive. Could I not just adjust the suspension? Is it something I could do at home? I'm pretty handy.
Old 04-27-2011, 07:52 AM
crimson850's Avatar
Member #5005
yes expensive. but it sounds like they may be faded? are they fox shocks? is it the front? change the rebound and preload a little and try that.
UNI air filter
oury grips
SSI decal kit
Old 04-27-2011, 08:03 AM
TheBatJon's Avatar
Member #13181
They're the stock Fox shocks that came with the ATV. They feel perfectly fine and don't sag when riding on flat land. It's only when I try and jump that they feel like they bottom out.
Old 04-27-2011, 02:35 PM
joshr08's Avatar
Member #13071
try adding more preload by turning the collar above the spring down to make the front end stiffer. i find it easiest to do this with the quad or at least the front of the quad off the ground. that takes the weight off the springs and lets your turn the collars with alot less tension
Old 04-28-2011, 05:25 AM
TheBatJon's Avatar
Member #13181
That's what I'll try. Otherwise i may try finding some beefier springs.
Thanks for the help guys.
Old 04-28-2011, 03:54 PM
joshr08's Avatar
Member #13071
not to many companies making spring kits for us bigger riders. I think HPD makes a kit for up to a 250 rider but they arent cheap.
Old 04-28-2011, 04:01 PM
TheBatJon's Avatar
Member #13181
@ joshro8: are you speaking in terms of weight of the rider or the cc of the ATV?
Old 04-28-2011, 04:05 PM
joshr08's Avatar
Member #13071
riders weight
adjusting preload on polaris predator
adjusting shocks on polaris outlaw
adjusting shocks on predator 500
how do you set up the rear suspension on a 04 ploaris predator
how to adjust suspension polaris predator
how to set the suspension on polaris preditor
how to soften polaris predator shocks
how to soften the shocks on a polaris predator 500
polaris predator 500 suspension setup
polaris predator shock adjustment
polaris predator shock settings
polaris predator suspension
polaris predator suspension setup
polaris+outlaw+suspension+set up
predator 500 recommended suspension settings
predator 500 suspension set up
predator suspension spring kit
race sag on predator 500
stiffer springs for polaris predator
550 xp suspension michaeltucker01 ATV Brakes & Suspension 10 01-08-2011 07:01 AM
air ride suspension Ransom Proctor ATV Brakes & Suspension 13 11-30-2010 10:23 PM
Suspension Change Vinnie0918 ATV Brakes & Suspension 0 09-09-2010 01:10 AM
Shiff suspension! whytezombie ATV Brakes & Suspension 5 05-31-2010 11:47 PM
Suspension settings tinman5255 ATV General Discussion 4 04-13-2010 05:11 AM
