Old 04-28-2011, 02:54 PM
Ta2edphreak's Avatar
Member #13890
Changing the front sprocket
any tips? do i need to remove the chain? im putting on a 14t sprocket.
2003 Polaris Predator 500
Dynojet 155 Main Jet
K&N Square Air Filter
Maxxis RAZR Tires
Acerbis Handguards
Tusk Comp Series Heelguards
Tusk Comp Series Nerf Bars
Tusk Front Bumper
Armadillo 6 Pack Rack
Trail Tech Big Bar Logo Clamp
Old 04-28-2011, 06:57 PM
bgwhtjp33's Avatar
Member #14249
What size is on it, 14t is stock
Your just jealous........cause the voices don't talk to you
Old 04-29-2011, 03:10 PM
Member #13890
i believe a 14t is on it now, it is stored 30 miles away or i would just run out and count them, i have a pic but i cant tell, i could post the pic if it would help?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 04-29-2011, 05:19 PM
bgwhtjp33's Avatar
Member #14249
Just wondering why you are changing it...it is easy to change, you will need to take the chain off.
Old 04-30-2011, 05:00 PM
Member #13890
any special tools needed to take the chain off?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 04-30-2011, 06:59 PM
bgwhtjp33's Avatar
Member #14249
The retaining clip can fly off, be careful not to lose it..........
Old 05-01-2011, 03:25 AM
joshr08's Avatar
Member #13071
you guys are doing this the hard way. loose the 2 bolts in the rear bearing/axle carrier. rotate the axle to loosen the chain and then take it off the rear sprocket. once you have the chain off the rear sprocket there is alot of room to slide the front sprocket off then put new sprocket in replace all bolts in the front then put the chain back on rear sprocket and rotate carrier back to tighten chain. theres no need to take the chain apart if your not replacing it.
Old 05-03-2011, 12:03 PM
Member #13890
you talking about the 2 bolts at the very back of the bike, one near the rear sprocket and the other near the rear disc brake?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 05-03-2011, 01:41 PM
joshr08's Avatar
Member #13071
yes your rear carriers pinch bolts. that is how you adjust your chain loosen those rotate it around until the chain is slack enough to take it off the rear sprocket. there are slots in the carrier that you can put a screw driver in or a punch or anything to get it to rotate around. then pull your front sprocket and replace everything then adjust your chain.
Old 05-14-2011, 07:38 AM
Member #13890
so i changed the front sprocket today, i didnt have to take the chain apart at all i pulled the old one off and then took the chain off the rear sprocket, installed the new one put the chain on it bolted it up and then put the guard back on, then i loosened the 2 bolts on the back of the carrier (there was an issue with the grease fitting being non-accessable earlier)
put the machine in neutral with a concrete block under the machine, resting on the stock plastic skidplate, then just rotated the tires by hand like you would on a bicycle, once the chain was on i rotated the carrier so that the grease fitting was easily accessable then tightened the 2 bolts back down, and i was done. i did notice a little play in the rear axle and worries with this? maybe like 1/16-1/8 of an inch.
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
2003 polaris predator 500 front sprocket stock size
2003 polaris predator 500 stock gearing
chain adjustment on polaris atv
changing front sprocket on atv
changing sprockets on atv with stock cahin
front sprocket polaris predator
how to change front sprocket on polaris
how to change front sprocket on polaris sportsman 6x6
how to change sprocket and chain on atv
how to change the sprocket on a polaris
how to loosen predator chain
polaris front sprocket removal
polaris predator front sprocket
polaris predator sprocket bolts
spockets on 03 predator 500
sportsman 500 sprocket 14t
what holds on a polaris predator front sprocket
what is the stock sproket size on a 2003 polais predator
Changing front hub bearings truckLoo44 ATV Repair and Maintenance 2 03-01-2011 06:39 AM
Front sprocket replacement gwalden309@aol.com ATV New Members 4 12-26-2010 03:18 AM
250 trail boss 4x4 front sprocket removal? Blackgk ATV Repair and Maintenance 1 10-27-2010 05:49 AM
front sprocket spacer? zeyn Polaris Outlaw 0 09-25-2010 05:08 AM
Oil comming around front sprocket 03Preda Polaris Predator 10 07-01-2010 07:42 PM
