04-28-2011, 04:01 PM
Member #14534
03 predator wont turn over or start
i have a 03 predator i turn the key wile in neutral and the neutral light wont come on the head lights work fine battery is charged but wont turn over or start tryed to jump start it but no luck push botton does nothing wile being pushed not even a click. plz help
04-28-2011, 04:26 PM
04-28-2011, 05:10 PM
Member #13071
first off i would clean all electrical connections. have you tried to start it by pulling the clutch lever in and hitting the button. if its not sensing the motor is in neutral it wont crank unless clutch lever is pulled. your neutral safety switch may have come unplugged or your bulb may have burnt out. after making sure its in neutral you can try jumping the starter solenoid to see if it cranks. if it does then either your power going to it is not getting power or might be your starter switch itself. if it doesnt crank then i would start with a new solenoid.
04-28-2011, 05:18 PM
Member #14534
i cleaned the major connections but ill try to get the rest of them tomorrow.wont start when clutch is pulled. it started yesterday night but nothing today thx for ur help
04-28-2011, 09:30 PM
Member #6880
Hellraizer I'm having a similar issue but my nuetral light works. It started slowly last year and got worse. I think I stumbled onto this: listed in my post.
What is this part?
2010 Laredo 291TG
2006 Dodge 5.9L CTD Megacab
2005 Polaris Predator TLD 500
2005 Polaris Predator 90
2004 Suzuki LT-Z250
05-01-2011, 10:25 AM
Member #14183
Im having a similar issue. I truned the key everything lit up.I hit the start button and it turned over several times.I let go of the button to pull the choke that I forgot to pull. Then I hit the button again and it won't do anything.out robert click oro make a sound.im like wtf. If anyone knows any advice please let me know.thanks
05-01-2011, 10:27 AM
Member #13071
where in michigan are you?
05-01-2011, 05:19 PM
Member #6880
Kikkin that's basically what I'm going thru. The diode in my post can be accessed under the seat. I ordered a new one thru the dealer, $12. I hope it's the problem?
2010 Laredo 291TG
2004 Suzuki LT-Z250
05-03-2011, 05:26 PM
Member #14183
Yeah i starts now but doesnt know its in neutral
05-03-2011, 05:28 PM
Member #14183
Yeah i starts now but doesnt know its in neutral. It only starts when I pull in the clutch
03 polaris predator 500 no power, 03 predator 500 starter and light switch, 03 predator starter switch, 2003 polaris predator starter button, 2006 polaris predator 500 starter clutch, 2006 polaris predator 500 when trying to start clicking noise and wont turn over, 90 polaris predator not cranking over, 90cc polaris not getting power to key, atv wont turn over, can i fix my starter relay om my predator 500, no power on my polariss predator 2006, polaris atv wont turn over, polaris predator 500 starter solenoid, polaris predator 500 starter switch, polaris predator 500 will not crank, polaris predator 90 wont start, polaris predator wont crank., polaris predator wont turn over, predator 500 neutral light doesnt work, predator 90 kick start stuck
