I am having starting issues. The starter works sometimes and not others. Its like I dont have power. But I do, the nuetral light works and so do the headlights. Battery may be 2 years old.
I replaced the starter only to work twice, then not again till tonite.
I was looking at the ignition coil to make sure there was good connections, thought about replacing.
When I looked at this relay? or fuse? I unplug it, the lights still work. I plug it back in and then accidentally hit my starter button it it starts. I unplug, hit the button-nothing. Plug it back in and it starts!
The markings on it is
100858
---l<--
It has a green and yellow wire,which I believe run to the handlebar switch-H/L/O/START
I was thinking about replacing it but cant find it in the manual or online??
I dont like being stranded out in the middle of nowhere, any thoughts?
