05-02-2011, 08:55 AM
Member #14656
Trouble Running
i have a 2003 Predator 500 and it runs great but after awhile it dies when on the trail... you wait 3 to 5 mins and it will start back up, but any sooner it will not. i am new to this site, so the more help the better.... thank you
05-02-2011, 02:39 PM
Member #13071
i would check tank vent first. next time it dies open the gas cap and see if it will start. welcome to the site.
05-02-2011, 03:07 PM
Member #13240
welcome to the site!
05-02-2011, 04:02 PM
Member #14656
thank you it is almost like there is an electrical heat up and it just shuts down until it cools down then starts again, what do u think about that?
05-02-2011, 04:21 PM
Member #13071
ok the black bag at the back of the quad will do that if it gets wet or dirty it can corrode the connections and cause your issue.
05-02-2011, 08:10 PM
Member #14656
i am confused as to what the black bag is, what does it do and do you know where it is?
05-03-2011, 01:05 AM
Member #13071
it is located back by rear subframe area right close to where it bolts to the main frame. you cant miss it. it looks like a black plastic bag that is sealed on both ends. I have never had to do anything with mine but my buddy knew as soon as i asked him about your problem. he said its like a little circuit or something in that bag
05-03-2011, 01:39 AM
WELCOME!!
After you check that vent, get yourself some SEA FOAM and use it!!
05-03-2011, 08:31 AM
Member #14656
thank you i appreciate all the help i will surely come back to this site when ever i need help, ohh i have one more question, it is minor, but my neutral light doesn't always come on. it comes on sometimes, only when it is running and sometimes when it is not running, what can cause that?
05-03-2011, 01:43 PM
Member #13071
loose connection or not getting a ground through the switch itself down on the motor.
03 polaris predator quits running, 04 polaris predator runs hot, 2003 polaris predator 500 motor diagram, 2003 predator 500 dies, 2003 predator 500 just dies when running, engine diagram for a 2003 polaris predator 500, fan turns on alot on polaris predator, fuse on 2003 prededor, lowering polaris outlaw subframe, outlaw 525 fuse breaker, polairs sportsman running great then shuts off want crank up wait few mins cranks back up, polaris 525 fuse location, polaris atv running amperage, polaris circuit starter black bag, polaris predator 500 quits running, polaris predator black bag, polaris predator circuit breaker, predator black bag, where+is+the+circuit+breaker+on+a+polaris+500 2003, winch on 03 polaris predator 500
