Old 05-03-2011, 07:47 PM
bkimbrel's Avatar
Member #14650
chain
Hey guys,how do you tighten a chain on a 2005 predator 500.what the best and fastest way.
Old 05-03-2011, 09:03 PM
Old 05-04-2011, 04:37 PM
buckwild kid's Avatar
Member #12643
short answer,
Loosen the two large bolts beside the brake rotor and sproket. then turn the eccentric disk with a C wrench or punch and hammer. I just did this on mine and opted to use a punch and a hammer to rotate the eccentric forward to tighten the chain. Before you do this you need to collapse the suspension with a cargo strap to get the swing arm level.
2003 Polaris Predator 500, FMF Power Core 4 full exhaust, K&N drop in filter
2000 Polaris Sportsman 500
2003 polaris predator 500 chain adjustment
2003 polaris predator 500 how to tighten chain
2005 polaris predator 500 chain tension
how do you tighten the chaib on 03 predator 500
how do you tighten the chain on 03 predater 500
how to adjust predator 500 chain
how to adkust polris 500 predator swingarm adjustment
how to tighten a chain on a polaris predator 500
how to tighten a polaris predator chain
how to tighten chain on 05 polaris predator
how to tighten chain on polaris predator
how to tighten chain on polaris predator 500
how to tighten the chain on a polaris predator 500
lowering the back of a polaris predator turning the swingarm
polaris predator chain adjustment
polaris predator chain tightening
predator 500 tighten chain
tighten a chain on a predator atv
tighten chain on predator 500
i need a chain fishook551 Polaris Scrambler 2 12-28-2010 01:48 PM
silent chain/reverse chain 1997scrambler4x4 ATV Repair and Maintenance 0 03-25-2010 02:23 PM
Hy-vo chain upgrade for silent chain/reverse chain 1997scrambler4x4 ATV Repair and Maintenance 2 03-10-2010 08:26 PM
