Old 05-04-2011, 04:41 PM
buckwild kid's Avatar
Member #12643
wire harness routing picture
I have an '03 and my wire harness coming off of the battery is just hanging in the rear fenderwell. I was wondering if someone could take a picture of how their harness is routed so that I can correct my situation. I am sure that mine didn't come from the factory just hanging out like a rats nest like it is. Thank you in advance.
2003 Polaris Predator 500, FMF Power Core 4 full exhaust, K&N drop in filter
2000 Polaris Sportsman 500
Old 05-07-2011, 04:34 AM
joshr08's Avatar
Member #13071
If i make it out to the shed today ill try to get you some pic of how i have mine ran all tho its probably not stock as i just rebuild my entire quad and ran it how i thought was an easy out of the way routing and then have it tied up to the frame.
Old 05-09-2011, 02:27 PM
Member #12643
Any thing is prob better than the way mine is, I appreciate it.
Old 05-09-2011, 03:09 PM
joshr08's Avatar
Member #13071
i was going to get you a pic until i realized i didnt have mine tied up at all yet...lol anyways the wiring goes on the inside of the frame and is supposed to be tied up to the frame and subframe from what i remember even from the factory the wires are still a mess under there. im just going to tie everything up and outta the way from any moving parts.
Old 05-09-2011, 03:15 PM
Member #12643
I guess what I am looking for is not the large positive cable that comes off the battery, but rather the large bundle of small wires that comes off the positive terminal along with it. I am not sure if it is supposed to be wrapped or what. Mine looks like a big hairball of wires hanging in my wheel well.
Old 05-09-2011, 03:19 PM
joshr08's Avatar
Member #13071
on my quad they arent wrapped up at all ill be in the shed this coming weekend and ill get you some pics of my wiring but there isnt much of it thats wraped up just wires going everywhere. altho i eleminated alot of wiring as i have no lights on my quad so all those wires are gone along with brake switches and things like that
you can always just disconnect the wires tape them up with electrical tape and reconnet them to neaten them up some
i just wouldnt remove any wires unless you know what they are for and if you need them or not.
Old 05-09-2011, 03:29 PM
Member #12643
I would appreciate that alot! Thank you
Old 05-09-2011, 03:37 PM
joshr08's Avatar
Member #13071
no problem ill get you some pics this coming weekend when i head out there.
02 polaris sportsman 500 wire routing
03 polaris predator 500 wiring
03 polaris predator wire harness
03 polaris predator wiring
03 polaris predator wiring harness
04 predator 500 wiring harness
2003 polaris predator 500 wiring
2003 polaris predator 500 wiring harnes
2003 polaris predator 500 wiring harness
2003 polaris predator wiring harness
2003 polaris predator wiring harness picture
color wiring harness polaris predator 500 2003
polaris predator 500 specs ground wires
polaris predtor 500 wiring
polaris wire harness
predator 500 ground wire located
predator 500 wire grounds?
predator 500 wireing
wiring harness for a 2003 polaris predator 500
Speedometer cable routing 3 Polaris Atvs Polaris Sportsman 1 02-22-2011 06:08 AM
1999 Sportsman 500 Wire Harness Pins Flipstick ATV Repair and Maintenance 3 09-13-2010 02:20 AM
2003 Trail boss wire harness carkrazd ATV Repair and Maintenance 0 02-03-2010 07:10 AM
2004 trail boss wire harness carkrazd ATV Repair and Maintenance 1 08-31-2009 07:07 PM
Wanted 2004 wire harness carkrazd ATV Parts for Sale 0 08-31-2009 06:59 PM
