Old 05-08-2011, 08:07 AM
shootnmiss09's Avatar
Member #12151
predator rear brake
Hey Guys!
I have been searching on here, and found out that a loose rear brake is common on the predators. Have any of you found any solutions to that annoying sound?
thanks
Old 05-08-2011, 09:39 AM
LEOGM5150's Avatar
Member #14419
make sure the axle nut is tight and there is no other slop anywhere as this will make the brake movement way worse. also check the brake bracket for slop on it's mounting point. i have found that wear on the bracket slot and the pivot pin on the swing arm where the slot rides is the biggest part of excess movement. i have cured 90% of it on my predators just by adjusting everything and making sure there is no movement or slop where there is not supposed to be. it is a floating rear break though and some movement and some noise will always be present.
2007 OUTLAW 525 IRS
2005 TLD PREDATOR HOT SEAT 600
2003 PREDATOR 500
2001 400 TWO STROKE SCRAMBLER
PLUS A DOZEN OTHERS...
2003 predator 500 brake change
2011 polaris outlaw 90 brakes
adjust rear brakes predator 500
brake drum removal on a polaris 90
brakes on polaris predator
change drum brakes on a polaris predator 90
disc brake conversion kits for polaris
how to adjust back brakes on predator 500
how to change brakes on polaris 90
how to change rear brakes on a polaris preditor 90
how to polaris predator back brakes
polaris 90 brakes
polaris predator 90 rear brake drum removal
polaris predator 90 rear brakes
polaris predator 90 rear brakes install
polaris predator rear brake
polaris predator rear brakes
predator 90 rear axle bearing remove
put brakes on polaris preator 90
remove brake drum from polaris predator
will a scrambler 500 rear shock fit on a 500 predator rear? hunter51190@yahoo.com ATV Brakes & Suspension 1 10-18-2010 04:18 PM
predator 90 disk brake upgrade polecat88 ATV Performance Modifications 3 05-15-2010 07:15 PM
predator 500 brake drag johnnyooo ATV New Members 1 02-05-2010 08:51 PM
2006 Predator 90 Brake Light pipern9368j ATV Repair and Maintenance 0 05-08-2009 06:51 PM
predator brake isssues 2005 tld shug41 ATV Brakes & Suspension 0 04-27-2009 06:17 AM
