i had a similar problem and had to replace valves , but also check the rubber boot between the carb for dry rot and the screw that tightens the boot to the carb, if its sucking air you going to have low rev problems
" Understeer is when the front tires hits a tree, Oversteer is when the back tires hit the trees, Horse Power is how fast you hit the tree and torque is how far you take the tree with you "
04 Predator 560 kit , carb tuned , cams, PowermaXX exhaust, port/ polish , air boxed removed. all motor parts from HPD and built by Nicholas Cycle < before he crashed poor guy > rear shocks internals replaced and tuned, Razr fronts and ITP MX rear, TAG bars , Ims Roll on shifter, NURF bars <dont remember brand>
