Old 05-10-2011, 05:31 AM
TheBatJon's Avatar
Member #13181
Oil in my airbox!
I was riding my Pred on some powerlines the other day and noticed that in the higher rpms my engine would bog down. I thought that was odd so I took my quad home and got to work. I took apart and cleaned the entire carb. But the first thing I noticed was that there was a large quantity of oil in the airbox (enough to cover the bottom plus some). There is a decent sized hose that runs to what I believe to be the crankcase. Anyone know why there would be oil in there? Or what that hose is for? I took off the air filter (which was nearly completely black) and it ran fine.
Old 05-10-2011, 12:58 PM
DARKPHREAK's Avatar
Member #12642
The hose is a crankcase vent. Not sure but a certain amount is normal atleast on mine.
Old 05-10-2011, 01:30 PM
M_Quick's Avatar
Member #13816
Did you roll the unit lately? I know my son had the 2001 scrambler on it's side almost over, and when we got it home and went through it I had oil in box as well. The drain port or plug on my box is pretty much imposible for me to reach. On my Honda its right there. This made clean up a real pita!
2001 Polaris Scrambler 500 4x4
(2) 2003 Polaris Sportsman 90cc
2006 Polaris Predator 50
2008 Honda Trx700xx
Old 05-11-2011, 05:45 AM
TheBatJon's Avatar
Member #13181
I figured it was a crankcase something since, well it leads to the crankcase. Fortunately, no I haven't flipped it. I was thinking that since the air filter was crap and clogged with dirt and black stuff that maybe there was some suction in the airbox which caused it to fill with oil from the crankcase. I was just trying to see on here if anyone else has had this problem with their Pred because oil ending up in my airbox somehow makes me a little worried.
Old 05-12-2011, 05:35 PM
Predasaurs's Avatar
Member #10140
happend to me before mine was because i used the predator oil change kit and it has to much oil in it i just overfilled it , and it pumped into the air box
03 polaris predator bogs out
2003 polaris predator. 500 airbox plugs
2006 predator 500 oil in air box
500 polaris oil in air box
atv air box filling with oil
oil got into my oil filter on my polaris 500
oil in airbox predator
polaris predator 500 oil in air box
polaris predator 500 oil in airbox
polaris predator oil in air box
polaris predator oil in airbox
polaris predator oil in the air box
polaris scrambler oil in airbox
predator 500 airbox
predator 500 too much oil on air filter
scrambler oil in air box
what would cause oil to be pumped into a air filter on a polars predtor 500
why is there oil in my air box
why would i have oil in the air filter box of my polaris predator 500
why would oil drain from air filter box on yamaha zuma
850XP Oil in Airbox! Makavel07 ATV General Discussion 18 05-08-2012 03:28 AM
Lot's of oil in my airbox.. slyder01 Polaris XP 67 06-29-2011 07:22 PM
Oil in Airbox eleaglesrock ATV Repair and Maintenance 1 04-12-2011 05:18 PM
oil in the airbox jered1321 ATV Repair and Maintenance 2 03-31-2011 10:25 AM
oil in airbox and will not rev up. 04tldpred ATV Repair and Maintenance 1 03-19-2010 05:03 PM
