05-15-2011, 07:26 AM
Member #12642
Predator quits
Was at a Poker Rally on Saturday. It was raining the whole damn day... 30 minutes into it my quad just stopped, no lights no spark no estart. After a few minutes the lights came back on and I was able to run it again. Then it did the same thing again, happened all day. What should I be looking for?
05-15-2011, 02:01 PM
Member #14419
it is the sealed black bag circuit near the rear of the predator. if it is getting wet or hot it will start doing just that. it needs to be replaced. either with the stock part from polaris. an after market one from hpd. or you could make one of your own from a self resetting 40 or 50 amp fuse from the auto parts store just make sure you seal it with some liquid electrical tape or you will have the same problem as the "sealed" one from polaris. they are not sealed at all and they let water and dirt inside and start to corrode and start shutting the quad off every time it heats up over and over with greater frequency.
2007 OUTLAW 525 IRS
2005 TLD PREDATOR HOT SEAT 600
2003 PREDATOR 500
2001 400 TWO STROKE SCRAMBLER
PLUS A DOZEN OTHERS...
05-16-2011, 03:59 AM
Member #12642
Thanks for the suggestions. After cleaning the 200 pounds of mud off I'll start making the self resetting fuse.
05-16-2011, 05:36 AM
Member #12642
The fuse you mention says 12v20amp. Any reason going to a bigger fuse?
05-16-2011, 10:39 AM
Member #10140
the two bags on my 07 are in the front and a little while ago my bike died on me 10 or so mins later it started back but , i was racing my bike when it happened
i rebuilt my engine and havent really rode it lots yet , but these bags do they just go bad or was my bike to hot
like should i repace it now so im not stuck on in the bush?
05-16-2011, 02:23 PM
Member #14419
they go bad. it could also just have been hot.
i am sorry if i gave you the wrong fuse size. i think the 20 amp one is for the fan and the other one had a bigger fuse but i could be wrong, it has been a while since i replaced one. i would just use the size that is in there.
2007 OUTLAW 525 IRS
2003 PREDATOR 500
05-18-2011, 01:12 PM
Member #10140
do u know what the other one says? mine is so corroded i cant read any #
05-18-2011, 01:57 PM
Member #12642
Ive only found the one, located left side panel near the CDI box. Bought a new one at Crappy Tire today, will wire it up in the morning. If you look on page 188 of the service manual wiring diagram its located center bottom.
05-18-2011, 02:11 PM
Member #14419
that is the one near the cdi that is for the running of the engine. the other one is under the front hood and it is for the operation of the cooling fan.
i was wrong about them being 30 or 40 amp fuses. they are both 20 amp fuses stock.
2007 OUTLAW 525 IRS
2003 PREDATOR 500
05-18-2011, 02:14 PM
Member #12642
Leo, forgive me but I cant locate the one you are talking about in the manual.
EDIT I found a 10 amp from the fan switch
03 polaris predator dies when it heats up, 2005 polaris predator 50, 2005 polaris predator 50 service manual, manual for 05 polaris 50 predator, polaris 500 stalls when letting off gas, polaris 50cc after hot shut down, polaris outlaw 50 hot up, polaris predator 50 quits, polaris predator 50 service manual, polaris predator 500 are there fuses, polaris predator 500 fuse box, polaris predator 500 fusible link, polaris predator 90 fuse size, polaris predator fuse, polaris predator quits running when going down hill, predator 500 dies, predator 500 dies when you let off starter, predator 500 fuse box', predator 500 fuses, were are the fules at on a 2003 plarois preditor
