Old 05-16-2011, 03:55 PM
buckwild kid's Avatar
Member #12643
9 inch rims
I was looking around for rear tires out of curiosity. I noticed that there really isn't crap for variety for our machines (10 inch rim). Then I looked up the same size tires but for 9 inch rims and found all sorts of different tires. Has anyone swapped down to a 9 and if so is there any benefit or downsides to doing this other than gaining tire selection?
2003 Polaris Predator 500, FMF Power Core 4 full exhaust, K&N drop in filter
2000 Polaris Sportsman 500
Old 05-17-2011, 01:49 AM
Ta2edphreak's Avatar
Member #13890
yeah there isnt alot of tire selections for the douglas rims, it seems like alot of work and dollars to be able to run a pretty common 9'' rear rim, to be able to run a 9'' rim you have to change hubs and carriers etc, or so i was told, so i guess we are stuck running the 3 tires that fit our rims..
Dynojet 155 Main Jet
K&N Square Air Filter
Maxxis RAZR Tires
Acerbis Handguards
Tusk Comp Series Heelguards
Tusk Comp Series Nerf Bars
Tusk Front Bumper
Armadillo 6 Pack Rack
Trail Tech Big Bar Logo Clamp
Old 05-17-2011, 06:12 AM
Member #12643
Well honestly I have a bent rim on the rear and one on the front from the PO so I was looking at getting new rims. I want some itp ss112's and they don't make them in the 156 rear bolt pattern so I was looking at getting the 110 bolt pattern rear hubs. That is why I am considering changing to the 9 inch rim at the same time.
Old 05-18-2011, 12:16 PM
Member #13890
well let me know hoy you make out on getting them to fit, im in the same boat as you, except my rims arent bent, but i need some decent tires that are good in the mud, i wonder if i put a longer swingarm on it if ide have enough room for a taller tire, not too big.
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 05-18-2011, 03:34 PM
Member #12643
I am sure that they will fit just fine, the offset will be the same, it will just be a hub change for the different bolt pattern and a 1 inch diameter difference in rim. Like I said, the ONLY reason I am considering the rim size change is for more tire selection.
03 polaris predator 500 bolt pattern
03 polaris predator rear rim size
03 polaris predator rim size
03 predator 500 rear hub size pattern
9 inch atv rims
9 inch atv wheels
9 inch atv wheels/rims
9 inch polaris predator hub
9 inch rim
9 inch rim polaris
9 inch rims
9 inch rims for a polaris
9 inch wheel polaris predator
9atv rims
9in rims on 03 polaris predator 500
atv rims to fit 03 polaris predator 500
atv tires with 9 inch rim
stock rear rim size polaris predator
what size main jet is used in a predator 500 with yosh exhaust
what size wheels for 2003 polaris predator
27 or 28 inch ITP 589m/s Mudisfun ATV Wheels & Tires 11 03-30-2011 06:29 PM
26 inch tires for 14 inch rims $150.00 Naga ATV Parts for Sale 3 01-05-2011 05:20 PM
2 inch lift kit...Ez install? MUDDIE49 Super ATV 3 10-11-2010 01:44 PM
12 inch wheels on xp! in2deep Xp ATV General Discussion 3 03-03-2010 06:07 PM
14 inch Bighorns darrell4wd ATV Wheels & Tires 6 12-26-2009 04:07 AM
