Old 05-20-2011, 12:36 AM
Mclark's Avatar
Member #15211
Jetting an 05
I have an 05 Predator 500, and just bought a pipe from Aaen, any suggestions on what size jet to go up too? P.S. I'm also running a K N airfilter.
Old 05-20-2011, 04:31 AM
Old 06-02-2011, 12:39 PM
Ruvalcaba's Avatar
Member #15578
i need to know if its a full or a slip-on exhaust, also if the air box has any mods "how many holes,where and how big" or just a clip-on k&n no air box!!! ill help you step by step on jetting. pm me thx.
Old 06-05-2011, 01:28 PM
Mclark's Avatar
Member #15211
The exhaust is a slip on, the air box has no mods, the K&N filters sits where I assume the stock one was, also I bought a Dynojet kit and followed the instructions, set the new needle on the second groove, and put a 175 main in, turned the air/fuel to 3 out, it was real responsive but in higher rpms it sputters and pops, I don't think its the rev limiter. I then put the 170 jet in and it still cut out but it feels like its at a higher rpm, but I don't have a tack so I'm guessing at the rpm thing. Any help is really appreciated. Matt
Old 01-20-2012, 04:49 AM
zfrederick's Avatar
Member #13106
I've got similar mods but I'm sitting at a 155 main. This was per cfmperformance.com. new jet is $3.50 at rocky mountain atv
2006 Outlaw 500 IRS
2005 Yamaha Raptor 660
Tao Tao 125
Baja 50
Blade 110 Kart
Buggy Kart with Kawasaki 600 Ninja (in Production)
Old 01-20-2012, 04:21 PM
joshr08's Avatar
Member #13071
your 155 is most likelyt stock type while he is running a dynajet kit. The needle and jets are different sizings the stock and makes it a pain to help when someone doesnt tell you that off the bat.
I only have 1 questions for you on WOT does it bog or sound like its on the rev limiter?
2006 polaris predator 500 nedle clip position
does polaris predator cut out at high rpms
polaris predator bogging in 2nd
will only cutting holes in airbox require jetting on predator
can and jetting ? eswiger ATV Performance Modifications 4 04-06-2011 07:45 AM
jetting where to start Predasaurs Polaris Predator 1 04-03-2011 06:19 AM
Jetting Danco411 Polaris Scrambler 3 03-29-2011 04:14 PM
help with jetting nooner ATV General Discussion 3 05-07-2010 01:07 PM
Jetting chrisford4x4 Polaris Sportsman 11 01-17-2010 04:54 PM
