05-27-2011, 09:03 AM
Member #15441
Polaris Predator 90 gearcase oil level
Hello all,
I have a Polaris Predator 90 and I want to check the gearcase oil but I'm not sure where the level should be. There is no dipstick just a port to add oil. Any help would be great. Also, does anyone have a link to a service manual to this bike? 07 Polaris Prdator 90.
05-27-2011, 09:41 AM
All mine on my 800 were to the bottom of the drain hole!
05-27-2011, 10:49 AM
Correct, you have a drain plug and a fill plug, you just fill the gearcase to the bottom of the fill plug
05-27-2011, 11:37 AM
Damn I was right! Mark the calendar!
05-27-2011, 03:55 PM
Member #15441
I found the sight glass on the gear case and it is half full. Another guy told me its usually filled until its half full. So now I guess I need to find out for sure where on the sight glass the oil level should be.
05-28-2011, 06:18 PM
Member #1628
I just changed the gear oil on My Son's Predator 90 I filled it to half way up the sight glass,Thats where it was before changing it & there was no leaks so I assumed that was correct.
08-07-2011, 04:56 AM
Member #17394
Where is the view glass?
08-09-2011, 09:25 AM
Member #7489
On the 05 I had the sight glass is on the starboard side of the gear case. The book states middle of sight glass, I always used 10w-40 motor oil.
2004 Predator 500 TL (next in line for rebuild)
2007 Scrambler
2008 Raptor 250 (sons)
2001 400EX (rebuild stage)
2002 polaris predator 90, oil, how much crank case oil does a predator 90 take, oil for predator 90, polaris 90 oil capacity, polaris 90 transmission oil, polaris 90 what gear oil, polaris outlaw 90 oil change, polaris predator 500 gear oil, polaris predator 90 case oil, polaris predator 90 chain case oil, polaris predator 90 gear oil, polaris predator 90 gear oil capacity, polaris predator 90 manual, polaris predator 90 oil, polaris predator 90 oil change, polaris predator 90 oil type, polaris predator 90 transmission oil, polaris sportsman 90 oil fill level, what kind of oil does a polaris predator 90 take, what kind of oul for polaris 90
