Old 05-27-2011, 01:26 PM
cooper99's Avatar
Member #14931
front bearings
could somebody give me a walkthrough on how to change the front bearings
the left tire is really bad it has shards of metal that spin with the hub, i've taken off everything to the hub and cant get the hub off on either tire. i've tried lots of wd40 and am going to buy pb blaster right now and see if that works.
BUT I CANNOT GET THOSE HUBS OFF, any advice would be killer, thanks
Old 05-30-2011, 01:41 PM
robertseber's Avatar
Member #5286
i just did this last week it took lots of pb and big hammer but the eventualy came off, was a bit** though.
Old 05-30-2011, 02:43 PM
Candybeard02's Avatar
Member #9885
If you have a pulley remover or a slide hammer it makes it much easier. Otherwise PB and a mallet. Make sure to use a piece of wood when seating the dust seals, otherwise the'll bend to hell. Other than that its pretty easy.
"The rippin and the tearin"
cant get front hub off polaris predator 500
cant get front left hub bearing off 20 06 equnox
how to change bearings on atv front
Changing front hub bearings truckLoo44 ATV Repair and Maintenance 2 03-01-2011 06:39 AM
trailblazer front bearings redneckmudder ATV Repair and Maintenance 0 11-21-2010 12:53 PM
08 outlaw 450 front hub bearings 92lowtoy ATV Brakes & Suspension 2 05-31-2010 11:44 PM
Front Strut Bearings and seals atvbuddy Polaris Scrambler 6 05-24-2010 05:05 PM
Front Hub Bearings Currinjason@aol.com ATV Repair and Maintenance 1 03-25-2009 08:13 PM
