Not running after long trip
A couple weeks back, I took the predator out and ran 120 miles on the trails. It ran fine. She died a couple times at idle, but its had that problem since I bought it. It does run a bit rich, always has.
I drove home in the rain and it sat in the bed of my truck over night in the rain. The next day I pulled it out of the truck and went to pull it into the garage and it wouldn't start.
I narrowed it down to no spark, and then I tested the coil and it had low resistance over the secondary coil. I replaced the coil and now she sparks like a mofo.
She still wont start. When I pull the air intake off and put my hand infront of the intake side of the carb, she is blowing alot of air out. I can put my hand over the carb to seal it and it will blow my hand off of it. I dont think this is normal.
Where do I go next?
