Old 06-05-2011, 12:30 PM
414tinner's Avatar
Member #15713
Predator front shock spec questions. Can anyone help me??
I was wondering if anyone had the stock front shocks off of their Polaris Predator that they could measure the extended length center of top eye to center of bottom eye and the exposed chrome shaft length. Slide the bottom out bumper up the shaft and you can get the true length of the exposed chrome shaft.
If anyone could get those lengths for me I would really appreciate it.
Thank you so much.
Old 06-05-2011, 05:43 PM
Old 06-06-2011, 02:02 PM
414tinner's Avatar
Member #15713
Thanks man!!!
Great to be here.
Old 06-12-2011, 02:15 PM
joshr08's Avatar
Member #13071
center to center is 19 inches IIRC not sure on the shock shaft measurement tho
Old 06-12-2011, 02:30 PM
414tinner's Avatar
Member #15713
Thanks man, you dont happen to have a set off of a bike that you could measure the shaft length for me could you?? I appreciate the info though.
Bryan
04 polaris sportsman 90 front shocks
19 inch eye to eye atv shocks
adjusting polaris predator front shocks
how to adjust front shocks on predator 500
length of a the polaris predator 500 shocks
lowered front shocks on 500 predator
polaris predator 500 front springs
polaris predator 500 shock length
polaris predator 90 shock setting
polaris predator front shock length
polaris predator front shocks eye to eye
polaris predator rear shock
polaris predator rear shock length
polaris predator shock length
polaris preditor front shock specs
predator 500 shocks lenght
predator shock adjustment
predator shock specs
WTB Predator Rear Shock atvbumm12 ATV Parts for Sale 1 03-09-2011 03:45 PM
Front shock play Ransom Proctor Polaris XP 6 12-17-2010 06:40 AM
What year did the predator come with a Walker Evans rear shock? sledneck_03 Polaris Predator 4 07-04-2010 06:06 PM
Predator shock question redneck2725 Polaris Predator 16 04-06-2010 01:27 PM
Predator 90 Compression Spec? gmiller0737 ATV Repair and Maintenance 0 12-14-2009 01:42 PM
