Old 06-09-2011, 07:04 AM
rosco12jr's Avatar
Member #15012
how do u know when to rebuild valvetrain?
just adjusted the timming with a new timming tensioner runs great no issues... except there is still chatter in the head, by process of elimination i know it is not the timming chain or any of that im thinking valve train is tired and needs to be rebuilt .... thoughts and opinions welcome
valves/springs...etc.
Old 06-09-2011, 07:58 AM
Johnnnyboy's Avatar
Member #15121
stretched timing chain ? valves new to be adjusted ? why did you adjust timing did it jump a tooth on the sprocket ?
2011 500 HO
Old 06-09-2011, 12:09 PM
Old 06-10-2011, 06:53 AM
rosco12jr's Avatar
Member #15012
the timming was off must have jumped a tooth cause of the failing tensoner... what further adjustment would i do to the valves ?
Old 06-10-2011, 11:05 AM
Johnnnyboy's Avatar
Member #15121
chech valve clearance. loose valves would make some noise.
2011 500 HO
atv valve rebuild
how do i change timing chain polaris predator 500
how much is it to rebuild timing chain on predator
how much to rebuild polaris 500
how rebuild valvetrain
how to change predator 500 timing chain
how to fix tensioner noise on polaris predator
how to rebuild valvetrain
pictured valve train
polaris 850 valve train pictures
polaris valve train
valve train rebuild
850 rebuild wildbill71457 ATV Repair and Maintenance 1 04-24-2011 05:23 PM
Rebuild 05 600 Tiger ATV Repair and Maintenance 0 04-22-2011 12:13 PM
Rebuild or Buy New matthewh05 ATV Repair and Maintenance 1 03-24-2011 05:39 AM
Just did a top end rebuild. But... itscody ATV Repair and Maintenance 2 07-04-2010 05:54 AM
Top End Rebuild? itscody ATV Repair and Maintenance 0 06-20-2010 06:43 AM
