Old 06-10-2011, 11:02 AM
jaywms's Avatar
Member #15429
Polaris predator gearing
I have 04 dale jr with 15/36 gearing has lots bottom end no mid or top it has pure polaris pipe 155 main jets and modify air box with k and n any suggestions on gearing
Old 06-11-2011, 11:33 AM
polarispredator62's Avatar
Member #15877
hey i got a 2006 predator 500 with full hmf exhaust 157 jet if am not wrong cfm airbox two kn&n am having same problem i have my on private mechanic an where going go two teeth down on back put a new sprocket.. my bike lifts on 4th gear it has massive low end but top end it dies so i recommend u going and changing ur sprocket for a top end it probably help the gearing way better
Old 06-12-2011, 02:14 PM
joshr08's Avatar
Member #13071
15/36 would be all top end i would check your jetting. 14/38 is stock gearing. i run flat track and run 14/38 on short tracks and run 15/36 on the half mile tracks. i would guess you are both lean on top end im dropping down because of a rich condition from a 175 and 4th notch on the needle to a 165 main and 4th notch on the needle.
04 polairs predator 500 stock sprockets
04 polaris pedator gearing
04 polaris predator 500 short gears
500 preditor gearing
best gearing for low end atv
gearing for a predator 500
gearing for atvs
how to modify air box polaris predator
modify airbox predator
my polaris predator has no 4th gear
no 4th gear polaris predator 500
polaris preadator gearing
polaris predator 500 gearing
polaris predator forum
polaris predator gearing
polaris predator stock gearing
predator 500 stock gearing
stock polaris predator sprockets
what is stock sprockets for predator 500
Polaris Predator 500 $2400 bretter89 ATVs For Sale 2 06-17-2011 06:34 AM
Trail Blazer Gearing webehillbilly ATV Performance Modifications 0 05-03-2011 09:00 AM
polaris predator DonkeyRacing Polaris Predator 1 04-05-2011 06:07 PM
05 Polaris Predator 500 Eagles22793 ATV Repair and Maintenance 8 01-19-2011 06:48 PM
03 polaris predator blksportsman ATVs For Sale 0 08-31-2010 12:53 PM
