Old 06-28-2011, 07:30 AM
lilpred500's Avatar
Member #16057
Whats with the front chain guide design?
Alright, I know Im not the only one that notices how bad the chain guide design is on a Predator 500 So.. Is there a stronger aftermarket replacement? I just replaced mine and have had the chain lubed religiously and only taken about 6 hours of ride time. Its already worn in 1/8"-1/4".
Do you guys just replace them every couple months or what?
Old 06-28-2011, 09:17 PM
Welcome to the board! Where in ID you from?
Old 07-08-2011, 08:54 AM
joshr08's Avatar
Member #13071
what sprockets are you running? if your running a 13 it will wear really fast. if your running to much slack it will wear fast. if your running with alot of preload on the rear shock it will wear fast.
2003 polaris predator 500 chain adjustment
adjusting front chain polaris
atv chain slider problems
chain adjustment on predator 500
chain slider polaris pred
chain tension on polaris predator
how to replace a chain tension on a predator 500
polaris chain slider
polaris front chain adjustment
polaris front chain tighting
polaris predator 500 chain slider problems
polaris predator chain guard 06
polaris predator chain slider
polaris predator chain slider or chain roller
polaris predatorchain length
polaris trailblazer chain slide replacement
predator 500 chain noise
predator chain length
preditor 500 chain teniion tool
slide, chain guide predator 500
whats the chain size on a 2003 polaris trailblazer 400!? jordaman17 Around The Garage 1 06-06-2011 12:33 PM
Whats this noise coming fro my front left wheel? twrhnd3 Polaris Predator 1 03-23-2011 10:58 AM
Front chain drive Spitfire79 ATV Repair and Maintenance 0 08-27-2010 12:44 PM
Guide rails on the front & rear racks of a Sportsman? moxie1884 Polaris Sportsman 2 06-28-2010 09:56 PM
how to adjust front chain newfiebud ATV Repair and Maintenance 0 05-09-2009 07:24 AM
