Old 07-03-2011, 12:30 PM
curb8's Avatar
Member #16484
gravity feedind fuel
have a 2005 predator 500. can i remove fuel pump and gravity feed fuel to a stock carb?
Old 07-03-2011, 12:45 PM
cwlongshot's Avatar
Welcome Curb!
I gotta tell ya, if that was a good idea the factory would have built them that way..,
Whats the issues?
Old 07-03-2011, 04:46 PM
curb8's Avatar
Member #16484
not getting enough fuel at wot. ive cleaned carb. new fuel pump. checked valve clearance. changed fuel lines. cleaned carb again put it back to stock runs better. fuel pump gets it pumping action from the pulse hose going to the motor. i dont think it is getting enough suction from motor. how does the pulse hose get its suction. what in the motor creates the suction. i also did compression check 130 with carb closed. 160 holding the carb wot.
Old 07-03-2011, 05:35 PM
curb8's Avatar
Member #16484
it is running out of fuel at wot. cleaned carb. checked valves. new fuel pump did compression check. put it back to stock runs better. thinking the pulse line is not getting enough suction for the fuel pump. what inside the motor creates the suction for the pulse line.
Old 07-03-2011, 09:26 PM
athacker's Avatar
Member #3985
Send a message via Skype™ to athacker
Have you Tried a new Plug? some plugs run fine but breakdown at high RPMS. (just a thought)
2006 Sportsman 500 EFI ( Green )
MODS:3 Light Mod, HID Lighting Upgrade, Front and Rear Bush Guards, Body Armour Fender Protectors, JamHard Rad Guard, Polaris Hand Guards, Front Rack Extender, Kimpex Rear Box, Handlebar crossbar for accessory mounting, Garmin extex legend GPS, UNI Air Filter, Rear Foot Pegs, Glacier II Plow System.
Old 07-04-2011, 06:04 AM
curb8's Avatar
Member #16484
tried 4 differ plugs doing plug checks . it has new fuel. what creates the suction in the motor for the pulse line? i was running the rath intake. hmf exhaust. 190 jet had it on dyno seems big but thats what it called for. needle clip 4th notch. 3 turns out a/f. ran great for about 5 years changed oil when needed. i maintaned it well. took intake off put stock back on. carb back to stock 157.5 main jet. runs better. at wot gets a little sputtery running like that for a liittle bit. . oh plug was chalk white with cold air intake did check for leaks around intake no leaks. cleaned little filters in gas tank. im lost now
bypassing polaris atv fuel pump
can you bypass the fuel pump on a polris trailboss
converting oil pump on 88 polaris trail boss
does polaris predator 500 have a fuel pump
fuel pump or gravity feed atv?
gravity fed fuel tank on an atv
gravity feed gas tank atv
how does fuel get to injectors on a 2006 polaris 500 x 2
how does the fuel pump on the predator 500 work
polaris 325 trail boss bypass fuel pump
polaris ok to bypass fuel filter
polaris prdator 500 fuel pump delete
polaris predator 500 cleaning fuel pump
polaris predator 500 fuel pump
polaris predator 500 fuel pump not working
polaris predator 500 gravity fuel?
predator 500 fuel pump bypass
predator 500 fuel pump forum
removing polaris predator fuel pump
trail boss 325 with no fuel pump
Fuel in air box Bruicer Polaris Magnum 4 06-07-2011 04:18 AM
2001 trailboss wont start, fuel issue, fuel pump? Judd ATV Repair and Maintenance 5 02-20-2011 08:05 AM
Fuel? duffer ATV General Discussion 19 02-15-2011 07:14 PM
06 500 x2 fuel inj. no fuel toadtwelve ATV Repair and Maintenance 1 01-28-2010 04:24 PM
fuel/air mix??? stevej ATV Repair and Maintenance 3 07-20-2009 07:14 AM
