Old 07-05-2011, 04:31 PM
rtherrington2's Avatar
Member #16548
2003 Predator 90 - no Spark
Had several opinions and have replaced the CDI and Coil - still no spark. The brake and fall-off safety switches seem fine (the rear light is on) but still no spark.
Please help! I've got $200 in this and summer is half way over!
Rich
Old 07-05-2011, 09:05 PM
Old 07-06-2011, 05:26 AM
tt425's Avatar
Member #3687
First make sure the safety switch is good. If not, bypass it for testing. Next check ignition switch. Then move to testing the stator.
Welcome to the forum.
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again)
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
Old 07-06-2011, 07:17 AM
Member #16548
Checking things...
Can I assume that if the tail light comes on, then the ignition and safety switches (brake and "fall off cord") are working properly?
If I trip these switches manually the tail light goes off.
Old 07-06-2011, 07:56 AM
tt425's Avatar
Member #3687
That makes sense. But I am not for sure. It might possibly be the stator. I have a 2001 sportsman 90 but the only problem I had with it was a carb issue,cleaned it and fixed it. I have heard of problems with the kill switch and the stator before. If it is the stator rickystator.com might offer an aftermarket stator for it. The dealership might can give you the ohm specs for the stator. I am sorry I can help you more.
1995 425 4x4 Magnum
Old 07-06-2011, 12:38 PM
Member #16548
I'll check the kill switch tonight. Does anyone know if the kill switch prevents the starter from turning, or just interrupts the "spark"?
Old 07-06-2011, 01:15 PM
tt425's Avatar
Member #3687
I think the kill switch grounds out the coil. But I am not 100% sure on that.
1995 425 4x4 Magnum
Old 07-06-2011, 05:06 PM
gmiller0737's Avatar
Member #1628
If you are refering to the switch on the left handle bar if it is "off" the starter will not operate.
Old 07-08-2011, 05:41 AM
Member #16548
So I guess the remaining items to check are the wiring harness and stator... it will have to wait till next week as we are headed out to D.C. for vacation. Will pick up this thread when I return.
Old 11-21-2011, 12:26 PM
Member #16548
Just wanted to update everyone...
It was the Stator which is simple to test.
I ordered the Ricky Stator for it and is cranked right up, sort of.
The engine runs but breaks up and 1/2 and higher throttle. I've thoroughly cleaned the carb and will start putting the old coil and cdi to see if a got a new bad part!
2003 polaris 90 no spark
2003 polaris 90 spark
2003 polaris predator stator
2003 predator 90
2003 sportsman 90 stator
90 cc polaris preditor no spark
no spark polaris sportsman 90
polaris 90 no spark
polaris predator 90 has no spark
polaris predator 90 no fire
polaris predator 90 no spark
polaris predator 90 not firing
polaris predator 90 service manual
polaris predator 90 stator
polaris predator stator test
polaris preditor 90 no spark
polaris sportsman 90 no spark
predator 90 coil
testing stator 2003 polaris predator 90
what wires on stator should have fire 90 predator
2003 polaris magnum 330 not getting spark foxrider_08 ATV Repair and Maintenance 2 11-21-2011 07:18 AM
2003 Sportsman 700 no spark Firefighter47 ATV New Members 2 03-13-2011 03:43 PM
2003 sportsman 700 intermintant spark midtown Polaris Sportsman 3 01-31-2011 05:44 PM
2003 Sportsman No Spark!! Ruppy ATV Repair and Maintenance 4 09-11-2010 06:54 PM
2003 Preditor 500 wont start!! turns over has Spark PLEASE HELP Xukh ATV Repair and Maintenance 13 02-19-2010 06:06 PM
