07-07-2011, 11:38 AM
Member #8631
rear axle bearing issues.
okay so i went to slide my 04 predator 500 over tog et it out of the garage and i realized my rear axle was super loose so i lifted it up and theres crazy amounts of play, are they adjustable or do i need new bearings?
im not very happy with this machine as the seller said he put new sprokets and chain on ( already replaced that all myself ) there is crappy welds at all the main joints, the tie rod ends are loose, bent shock, and now the rear bearings are shot.
07-14-2011, 12:39 PM
Member #16157
yuppp wheel bearings are shot bud. thats happened to me a hand full of times. easy fix though.
-03 400ex hotcams stg 2, white brothers exhaust, wiseco pistions, jetted, air box.
-05 tld predator 500 hotcams stg 1, big gun rev,hpd high output starter, cfm airbox dual k&n, hmf competion series exhaust, ac bumper, rock grab bar, sand stars front and back soon to be +4 swing arm and +2 racesin a arms.
-2375 vw sandrail
07-14-2011, 02:43 PM
Member #8631
figured as much. how do i go apart getting to them?
07-15-2011, 09:26 AM
Member #10140
could also be your big nut on the axle came a bit lose mine did and i g tightend it up
07-15-2011, 12:57 PM
Member #16157
Yeah it could be that nut aswell. But take off the axle nut sprocket hub and caliper. Pop out the seal hol,ding in the bearing and it should all slide out. Check your housing i had to replacve mine the last time i blew my bearings
-2375 vw sandrail
07-15-2011, 04:54 PM
Member #8631
it could just be loose, ill check that out tomorow... it went from being good one day to no good the next.
07-22-2011, 08:33 AM
Member #635
Same story here. I recently bought a used 05 that recently had new rear bearings and housing. It looks like they are loose again (and I have ridden it about 1 hour) After looking more at the machine I found it needs all new front wheel bearings, ball joints are slightly loose, Shock bushings are loose front and rear. Luckily the tie rod ends were changed right before I bought it! What a pile.
2005 Predator 500, Holeshot HD's, Pure Polaris slip on, 1" bar riser. (Mine)
2005 Sportsman 700 EFI, EPI clutch kit, Aaen megaphone muffler, 27" Highlifter Outlaws. (Mine)
2002 Sportsman 500 H.O. Remington Edition, 26" PXT's. (Wifes)
2001 Trailblazer 250 (Son #1)
2007 Phoenix 200 (Son #2)
2003 Predator 50 (Son #3)
03 polaris predator rear wheel bearing, 2005 polaris predator rear axle bearings, 2007 polaris predator 500 rear end problems, atv rear axle nut predator, changing rear axle bearings on an 2005 polaris predator 50, how do you get the rear end apart on a polaris outlaw, how much grease in bearing in swing arm o 04 predator, how take apart an axle for 03 polaris predator 500, how to change rear wheel bearings polaris 800 2005, how to change the rear bearings on a polaris outlaw, polaris predator axle housing, polaris predator front sqirrelly, polaris predator rear axle, polaris predator rear end, polaris preditor axle bearing change, polaris rear end bearing out, polaris trailblazer 250 rear axle bearing removal, predator 500 loosen back axsle, predator bearings replaced and now loose, rear axle is loose on atv
