07-11-2011, 12:55 PM
Member #16695
4th Gear won't engage
My buddy just picked up a '03 Predator and he took it out for the first time this weekend. It seems to be running fine except it won't engage in 4th gear, it just revs out like it's in neutral. He can run 1-3 no probs and then he can kick it in to 5th and it works, but no 4th.
Anyone ever had this problem, or know what it could be?
Thanks,
07-11-2011, 07:06 PM
07-11-2011, 07:48 PM
Member #16228
Dam... now you know why it was up 4sale!
sounds like a bad Gear in the trans, Drop the oil and check your oil Filter for metal shavings.
DO NOT drive the Quad Asis you will DO way more damage
07-12-2011, 07:50 AM
Member #16695
I was thinking that it might be the gear, but you would think that it would at least grind a little and try and go into gear...I was thinking it might be the shift fork not fully engaging in 4th gear and keeping it in Neutral...I have to admit though I'm a Banshee guy so don't know too much about Polaris'.
07-14-2011, 12:37 PM
Member #16157
its most likely the gear. could be the timing too. one one of my old bikes we fucked up the timing and 1st gear was now reverse so check those
-03 400ex hotcams stg 2, white brothers exhaust, wiseco pistions, jetted, air box.
-05 tld predator 500 hotcams stg 1, big gun rev,hpd high output starter, cfm airbox dual k&n, hmf competion series exhaust, ac bumper, rock grab bar, sand stars front and back soon to be +4 swing arm and +2 racesin a arms.
-2375 vw sandrail
07-16-2011, 09:32 AM
Member #13071
it probably isnt doing any grinding as the gear is prolly laying in the bottom of the motor. 03's were known for weak trannys. now to do that tranny fix you have to pull the motor and split the cases in half. you have to strip the entire motor to split the cases too. good luck.
07-26-2011, 07:33 AM
Member #11961
From my experience with the predators the 2003 predators have weak transmissions, its probably a bent fork
07-26-2011, 02:33 PM
Member #17047
yeap sounds like 4th gear completely gone,i would change all the gears and new clutch plates and new piston and rings gaskets and seals.with a rebuilt motor and a few mods this motor really rips.we flat out smokes all the 660 raptors we faced in our town.
12-10-2011, 02:08 PM
Member #21253
i have had the same problem with mine twice, it has been a bent shift fork both times........ from my 16 yr old son jumping my quad, these 03,s wert ment to be jumped i quess.. 1000.00 bucks each time
03 polaris predator 500 no fourth gear, 03 predator 500 transmission rebuild kit, 04 500 predator 4th gear slipping, 04 predator 500 tranny problems, 06 gears in a 03 polaris transmision, 2003 polaris predator 500 not good from 4th to 5th gear, 2003 polaris predator 500 transmission, 4th gear not working on polaris predator 500, how to repair polaris predator 4th gear, my 05 predator will not engage into 3rd gear, my polaris predator has no 4th gear?, polaris predator 500 4rth gear, polaris predator missing 4th gear, polaris predator trannsmission rebuild kits, predator 500 4th and 5th gear wont engage, preditor 500 shift fork, prolems shifting from 3rd to 4th on my polaris predator, why will my polaris predator engage into 3rd gear, why will my polaris predator not go to 3rd gear, why would predator polaris third gear quit
