07-12-2011, 07:49 PM
Member #16740
04 predator not starting when cold
My 04 predator will not start when letting sit over night takes a long time to get it to start but once i get it going its fine all day. seems like it came on fast like one day it started fine and the next not at all. checked for spark, replaced the plug, checked for fuel to carb, it all checks out. when i get it to start it runs like a raped ape!! only thing left that i can think of is valves i have owned it for 3 years and have never touched the engine internals. Thanks for reading any help would be great!
07-12-2011, 08:37 PM
07-13-2011, 01:03 AM
Member #16228
sounds like fuel pump losing it's prime
07-13-2011, 04:01 PM
Member #13071
even if fuel pump is losing its prime it should still fire off whats in the carb bowl. i would check the valves.
07-13-2011, 05:05 PM
Member #16740
checked fuel prime its staying primed, i guess i'll be reading up how to adjust valves?
07-16-2011, 10:56 PM
Member #15540
Its not to hard once you know what you are doing. I will be doing mine next week and I plan on making a video of how it is done.
The hardest part is getting the timing set up again. The math for figuring out your shim size is also confusing, but once you know it, its easy.
07-17-2011, 04:25 PM
Member #16740
be sure and post it here or let me know where it is!
07-19-2011, 11:20 AM
Member #15540
The video will probably have to wait until next week. It is just too damn hot out to work in the garage. I went out change the spark plugs in my truck and in a half hour I was soaked with sweat. We will see what tomorrow brings. If not it will have to wait until next week.
Do you know how to tear down your head and get to the shims? If so I can make a video just containing the math part of it.
07-19-2011, 11:25 AM
Member #16740
im sure i can get it tore apart easy and no hurry im with you on the whole heat thing im out side in it all day dont really want to go home at night and do it all over again thanks again
04 polaris wont start cold, 05 predator wont start cold, atv not starting cold, cold start polaris predator, not starting when cold, polairs predator cold start, polaris atv not starting, polaris predator 500 cold start, polaris predator 500 timing, polaris predator 500 will not start when cold, polaris predator not starting, predator 212 wont start, predator 500 cold start, predator 500 front sprocket, predator 500 wont start in cold, predator 500 wont start when cold, predator not starting, predator wont start in cold? ?, problems starting predator when cold, what side is the timing on a polaris predator
