Old 07-17-2011, 06:02 AM
polarpred500's Avatar
Member #13400
Smoking bad after oil change
04 pred 500, was not smoking at all before, change the oil and i think i put to much oil back in it because as soon as i started it started smoking like crazy and was some oil leaking out the exaust. so drained everything again and filledd it up right and drove it for probly an hour and still smoking like crazy. drained the oil AGAIN and less came out then what i put in. Again right before that first oil change bike worked great and didnt burn any oil. Also new oil filter is in right.
thanks in advance.
04 predator 500 dale jr edition
-pure polaris/white bros pipe
-pro armor nerfs
-rethal grips
-dynojet
01 honda trx 250
06 ski-doo rev
Old 07-17-2011, 03:53 PM
starpuss's Avatar
Member #16228
did you clean your air box out after you over filled it?> But i dont see how you can over fill it... the oil tank will not let you over fill the motor, but you can over fill the oil tank.
Old 07-17-2011, 04:23 PM
Member #13400
Ok I must have just over filled my oil tank then. I dont know but I just misread the dipstick and when I changed it later I realized I had put too much in. So like I said I drained it out and the right amount is in it now BUT, it is still smoking, but not as bad. And no I did not clean the filter.
-pro armor nerfs
-rethal grips
-dynojet
01 honda trx 250
06 ski-doo rev
Old 07-17-2011, 06:56 PM
starpuss's Avatar
Member #16228
i know you say the "new oil filter is in right" but you sure... take it out one more time, maybe you killed your motor buy not installing it right.
if it's not smoking as bad i would say your filter got coved with oil from the crank case vent when you over filled her.
Old 07-17-2011, 07:07 PM
Member #13400
Thanks for the help I will drain the oil and recheck everything again in the morning
-pro armor nerfs
-rethal grips
-dynojet
01 honda trx 250
06 ski-doo rev
Old 07-18-2011, 05:30 PM
Member #13400
So did everything I could think of and still smoking and burning oil so I pulled the gas tank and head cover, and theres oil in and around the cams, wondering if there is supposed to be oil there? Also plug iss verrrrryyy dark.
-pro armor nerfs
-rethal grips
-dynojet
01 honda trx 250
06 ski-doo rev
Old 07-18-2011, 07:43 PM
starpuss's Avatar
Member #16228
yup there should be oil there.
did you check your air box yet?
Old 07-18-2011, 09:18 PM
Minnesota's Avatar
Member #15540
You are burning oil. So now the job is to figure out how.
Is your plug dark and dry or dark and wet. If it is dry, you are running very rich. If its wet you are burning oil.
If you added too much oil it could have pushed past the rings and scored the cylinder walls in the process. I dont know if this is possible with the dry sump system though.
Old 07-19-2011, 06:20 PM
Member #13400
Airbox and filter has been cleaned, plug is very dark and wet.
-pro armor nerfs
-rethal grips
-dynojet
01 honda trx 250
06 ski-doo rev
Old 07-19-2011, 06:21 PM
Minnesota's Avatar
Member #15540
Time to start tearing down the top end.
03 polaris predator dies when it heats up
atv smoking after oil change
atv smoking after putting oil in
atv smoking too much
atv smoking when started too much oil
atv was smoking and now its not
my polaris predator 500 smokes
polaris 500 smoke after oil change
polaris 850xp oil overfull
polaris predator 500 wont rev
polaris predator smokes
polaris predator smoking
polaris sportsman smoking after oil change
ppredator 500 smoking
sportsman 500 smokes after oil change
the oil tank is smoking
why does my polaris smoke after an oil change
why is my 98 polaris xplorer smoking bad
why is my polaris 500 smoking
09 SP 400 HO A-Freeze in oil and smoking JoeG ATV Repair and Maintenance 7 04-22-2011 09:57 AM
850 xp smoking frye7077 Polaris XP 11 12-11-2010 04:15 PM
98 400 xplorer smoking bad kayden101 ATV Repair and Maintenance 1 05-07-2010 04:07 AM
sportsman 90 smoking steiny93 Polaris Sportsman 1 04-05-2010 08:32 AM
Smoking polaris darrellnell Polaris Sportsman 4 10-08-2009 04:28 AM
