Old 08-03-2011, 10:30 PM
bailo's Avatar
Member #17380
Engine problem
Hi
I build a new engine for my predator.... and have a problem... doesn't start.....
outlaw 500 based engine
558 wiseco
4 HPD oversize valve
HPD valve springs
hot cams stage 1
light flywheel
hinson clutch
reworked head
mikuni hsr 48
complete inox exhaust
procom cdi
I have a claymer manual for problem..... but the flywheel position i ok, cams timing is ok (on original points) compression is ok, spark running ok, fuel is ok (for test I use original carb)..... the engine do not start.........
Have a ideas?
thanks
bye
Old 08-04-2011, 06:36 AM
Old 11-12-2011, 11:30 AM
Alie3660's Avatar
Member #20383
I am dealing with pretty much the same problem. I am starting to wonder if somehow the coil is bad? I sprayed a very little bit of starter fluid on plug and put it back in cyl and mine is not firing when plug is in cyl. When the plug is out I have good fire. Anyway I just thought maybe it could be the same for you. If you have already found a solution I would love to hear it. Otherwise I I figure mine out I'll let you know what was wrong with mine.
Drew
Old 11-12-2011, 01:17 PM
joshr08's Avatar
Member #13071
by chance is it pushing air out the carb?
Old 11-12-2011, 01:20 PM
Alie3660's Avatar
Member #20383
No it's sucking. I am at a loss on this one.
Old 11-12-2011, 02:37 PM
bailo's Avatar
Member #17380
Hi
I resolve my problem....
I have a flywheel problem.....
changed it and I resolve
thanks
bye
Old 11-12-2011, 02:50 PM
joshr08's Avatar
Member #13071
broke keyway?
Old 11-12-2011, 02:51 PM
bailo's Avatar
Member #17380
small video with 42 carb and standard cdi, i buy dyna fs, but I have a software problem...
Old 11-12-2011, 02:52 PM
joshr08's Avatar
Member #13071
now i hate to tell you but with those hot cams your going to lose top end power.
Old 11-12-2011, 02:54 PM
bailo's Avatar
Member #17380
Originally Posted by joshr08 View Post
broke keyway?
yes, the home of flywheel cone is bad (damage on disassembly engine) and crash woodroof...... ressolve with another flywheel (only light )
I have a software problem with dyna fs......
bye
03 polaris predator 500 engine troublee
04 polaris predator 500 ehgine problems
04 polaris predator problems
560 polaris predator engine build
does hpd-inc starter work good for predator
hsr predator 500
keyway for quad
polaris atv engine problems
polaris engine problems
polaris predator 500 engine life
polaris predator 500 piston problem
polaris predator 500 top end power loss
polaris predator engine noises
polaris predator exhaust and intake cams
predator 500 engine problems
predator 500 keyway
predator engine problems
predator wont start forms
New guy..engine start problem kdsberman Polaris Sportsman 6 06-20-2011 03:40 PM
engine problem popo7 ATV Repair and Maintenance 5 04-26-2011 07:46 AM
Engine Problem silveradoblk ATV Repair and Maintenance 2 11-25-2010 06:50 AM
Engine Problem silveradoblk ATV Repair and Maintenance 0 11-24-2010 06:12 PM
Sportsman 500 engine problem zyggi ATV Repair and Maintenance 9 10-12-2010 03:13 PM
